Removing rear shock upper mount bracket from shock?
Old Jul 2, 2007 | 02:15 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
Default Removing rear shock upper mount bracket from shock?
A forum member has asked me to give him my factory rear upper shock mounts. I purchased the LPE minitub mounts and put them on my Bilstein Sports when I did the install. I can’t figure out how to take the factory bracket off of the shock. There is a 15mm nut, and the bolt it is threaded onto has a flat at the top. I can hold the flat with pliers and back the nut off, but once I get to the last few threads there is no way to keep the bolt from rotating since the nut is right on top of the flat.
How do I get this thing off?
Old Jul 2, 2007 | 03:51 PM
FRCTony's Avatar
FRCTony
Air wrench will work. If you don't need the shock, you can probably slip some needle nose vise grips on the shaft.
Old Jul 2, 2007 | 04:08 PM
SLO C5's Avatar
SLO C5
Cruise-In X Veteran
St. Jude Donor '09
I tried vice grips and a set of needle nose pliers, but they both just get in the way of the nut I'm trying to take off. I don't have access to an air wrench
To Removing rear shock upper mount bracket from shock?
