parasitic battery drain
Old Jul 2, 2007 | 06:16 PM
trophystock's Avatar
trophystock
Default parasitic battery drain
My optima red top is not holding a charge. Before I pulled it out to take it back to Advance Auto I check the parasitic drain on it. I had .20 A or 200mA draw. Is this considered normal?
Old Jul 2, 2007 | 06:21 PM
ZeroHer0's Avatar
ZeroHer0
do you have any aftermarket elctronics in your car? If not check for corrosion on the cables beneath the battery tray.
Old Jul 3, 2007 | 01:36 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Another place that is a trouble spot is the driver's side electric seat switch--they go bad quite often and stay on all the time---mine went bad--I just set the seat where i wanted it and unplugged the pigtail under the bottom- battery stayed up--
Old Jul 3, 2007 | 07:57 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Had the same problem with my Red Top. Had to keep a trickle charger on it until the other day when it went completely dead. As soon as I put the big charger on, I hear the driver power seat motor whirling and figured the switch was bad. As mentioned above, you can unplug it or as I did, open the fuse box cover under the passenger side floor panel and pull the fuse. I suspect water gets on the switches from opening the door in the rain and eventually causes the problem.
Old Jul 3, 2007 | 12:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your BCM sleep current draw should be very close to 0.020 A. NOT 0.200: It will take about 3-5 mins for the BCM to go into sleep mode once you connect the amp meter to the circuit. Make sure everything is off, shut or disconnected. I.E. doors, trunk, hood light off, radar detector unplugged ect....
Check out this post.
http://forums.corvetteforum.com/show...attery+current
There are quite a few batter current drain post in the C5 Tech section "archive" section. Search under these definitions;
poster "Bill Curlee"
Battery Current Draw, or current draw,
C5 Tech section
Archive
BC
Old Jul 3, 2007 | 05:06 PM
trophystock
thanks, the .20 A was after about 30 seconds. I took the battery in today and it tested bad. I will put the new one in and recheck the load after 5 minutes or so. Thanks everybody.
To parasitic battery drain
