HELP....... Need alternator info
Pulled the battery and went to Autozone. Got it charged and checked, it was good which means that the alternator probably has an issue.
So the battery is good. I decide to drive the car to the airport 70 miles away
As I drive I see the voltage steadily going down and finally about 10 miles from the airport the gauges go dead, ABS and TCS warning flash and basically the battery is at 6-7 volts. As I pull up on the offramp to the airport and the engine hits higher RPM as I downshift the volt meter jumps back up to 12-13 and all seems good as I park the car.I come back three days later, get in, it barely turns over and starts but the low voltage, TCS, ABS lights come on almost immediately. It is night so I have to use the headlights. By the time I get from the inside parking lot to the outside lot the guages go dead and the healights are very dim. I pull into a space, turn it off and the car is dead (only clicks when turned over). I have to have the car towed 72 miles home and it sits out back dead right now.
First question, what is the order I should check out possible causes? I am pretty sure I got the ground loop straps connected back correctly after header installation but maybe there is something I dont know about?
Second question, I have heard that some places can rebuild your alternator and make it better (stronger, etc). Who would do that?
Third I can get a new alternator from Autozone for $149 or can buy a used OEM for $12x.00 with 40k miles on it. Which should I go for?
If you have any knowledge on any of these issues please help me out. Thanks
Cajun
Bill is a retired GM engineer and made a number of posts on the topic.
Bascially the C5 is quirky and needs a specific alternator. Many replacement ones will not work.. If I remember it has to do with the system checking the resistance of the alternator.... if you do not buy a replacement with the same resistance it will not work...
You are better to have yours rebuilt.
Look for auto electric shops, generators, alternators in your local yellow pages
Check all of that stuff out before you have the alternator replaced or rebuilt.
BC
I had a no start after my header self- install.... Bill helped me find the problem.
I had missed one of the ground wires that was supposed to connect to the ground on the passenger side of the block above the starter.
Did you do the header install yourself?
Did you have to disconnect the ground wring on either side of the block?
Did you have to disconnect the wiring to the starter?
It may be that those terminals are not clean or properly torqued.
BC
BC
The other thing to check is the wiring on the passenger side of the engine. If you installed headers and started having this problem shortly afterwards then the wiring may be to close to the header or even touching it and there are a couple of threads out there where people have found the wiring burned or melted around the passenger side header.
OUTSTANDING additional info! I didnt think about that.
BC
I am really starting to get worried here because the car is doing crazy stuff. I can hear a clicking on and off when I have the hood up and then the light in the engine bay will get dim as the battery drains. It will lock/unlock over and over again.
Then when I shut it off the security light kept blinking and the dinging sound would not stop even with all doors and hatch shut.
Bill I will PM you to see if you can give me anymore guidance so I can try to get this fixed. I have to drive this car from NY to NC in three weeks because the Army is moving me. I have to get this fixed and quickly.
Cajun
Cajun
