Column lock-CLB
Old Jul 3, 2007 | 06:41 PM
Greg C5's Avatar
Greg C5
Default Column lock-CLB
Just a couple of quick questions on the CLB.
I have read most of the column lock and CLB questions, so I'm somewhat familiar with the situation. I was telling one of my Covette friends about the situation, as he had not heard about it, but he also doesn't visit this forum.
Anyway, he has a 2000 A4.
The steering does lock in place when the ignition is shut off. I told him that most likely, he hasn't had the GM recall done. He did check with the Chev dealer who ran the VIN and there was no idication of the recall of the K harness being installed.
I suggested that he purchase a CLB from Corvettes of Houston.
My questions are these:
1) Should he install this right away? and just be done with it.
or
2) Purchase the CLB and just keep it in the car. When and if the steering locks up, then replace it. Or will the CLB not work once the steeing locks up and is there more of a process of installation once the steering locks up.
Thanks for your help and information.
Greg
Old Jul 3, 2007 | 07:17 PM
Bob CTS's Avatar
Bob CTS
Originally Posted by TEXHAWK0
The only problem with waiting until the column locks to install the bypass is that you have to get the column to unlock to install it.
The bypass will not unlock the column. The column has to be in the unlocked position before you install it, then it takes the actuator out of the circuit so it cannot lock.
I would go ahead and remove the lockplate, then install which ever bypass you want. If there is a good local dealer, it would be worthwhile to take it to the dealer and tell them you want the recall done so you can get the lockplate removed for free. They will install the Harness K, but you can always change over to the aftermarket bypass.
Old Jul 3, 2007 | 07:18 PM
TEXHAWK0's Avatar
TEXHAWK0
You could let the dealer install the Harness K and carry the CLB in case it fails. At least with the lockplate removed, you do not have to deal with a locked column. If the Harness K fails, you could just replace it with the aftermarket bypass.
Old Jul 3, 2007 | 10:08 PM
robsciam's Avatar
robsciam
i just went through this so i would buy the bypass and just install it, it only took about 15 min. ( and iam a momo) good luck.
Old Jul 3, 2007 | 10:50 PM
Oldvetter's Avatar
Oldvetter
If you let the dealer do the recall, he will reprogram the computer to shut off the gas at 2 mph if the CLB fails. This prevents you from driving with a locked column (liability for them). BUT, it will also disable your car if the CLB should fail.
Just install a private CLB (I did Corvettes of Houston), it is your best solution.
Old Jul 3, 2007 | 11:02 PM
Slick Rick's Avatar
Slick Rick
I have a 97 A4 that none of the recalls had been done. I had the dealer do mine for the reason texhawko mentionend. Removing the lock plate in the steering wheel. Also has the k-harness. Have put 2,000 thousand miles on it since it was done and not a single problem.....
Old Jul 4, 2007 | 07:36 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
you could let the dealer install the Harness K and carry the CLB in case it fails. At least with the lockplate removed, you do not have to deal with a locked column. If the Harness K fails, you could just replace it with the aftermarket bypass.
I absolutely agree EXCEPT I'd suggest to just replace the K Harness right away with the CLB. K Harness is junk and will fail in short order .
Old Jul 4, 2007 | 09:54 AM
bliehr's Avatar
bliehr
So what is the bottom line here for the best solution to this problem?
Go with the Dealer recall, or do the after-market CLB?
I just purchased a 97 with low miles and still has the CL. I want to do what it takes so I dont have to think about it again!
Old Jul 4, 2007 | 10:08 AM
Melsy's Avatar
Melsy
I had both recalls done b y the dealer. No problems--but I do miss the added security of the locked steering wheel. Let's hear it for the GM geniuses!!
Old Jul 4, 2007 | 10:32 AM
bliehr's Avatar
bliehr
Both recalls? If the CLB is one , is the K harness the second?
I just checked my car and I can not turn the wheel without the motor running. I have a little movement key in and key out. I really cant tell about the CL but I can hear the unit run.
If the dealer performed the recall work, will the unit still make the sound as if it is working?
Old Jul 4, 2007 | 04:42 PM
Greg C5's Avatar
Greg C5
If you had the GM recall, the column lock plate has been removed and you will be able to turn the steering wheel as far as it will turn when the car is turned off, with a little effort. And yes, if you had the recall, it will still "sound" as if the column is locking or unlocking.
Greg
Old Jul 4, 2007 | 04:44 PM
Greg C5's Avatar
Greg C5
Thanks for everyones input.
I will pass this on to him and let him make the call as to what he wants to do.
As for my 1998 A4, it had the GM recall done before I bought the car. I will likely just ride it out and hope that nothing happens. I hope that I don't regret that decision.
Greg
Old Jul 4, 2007 | 08:40 PM
Dustie's Avatar
Dustie
Default Clb
I see you have the same vintage car as mine Greg..(98). I bought and installed a CLB after the dealer did the recall figuring I would avoid any future issue...wrong. The CLB doesn't work on all early C5s and in my case made the situation worse. Had to remove it. The column doesn't lock anymore but about once every 2 months I get the dreaded "pull key" message and have to restart the car. At this point, not a big deal for me.
Old Jul 5, 2007 | 06:39 AM
Greg C5's Avatar
Greg C5
Yeah, I've had the "pull key wait 10 seconds" happen to me twice in the past 7 months. Not a big deal at this point.
From what I've read here though, there could be other things causing this symptom. So, not sure if it is related to the column lock issue.
Greg
Old Jul 5, 2007 | 10:22 AM
jovette's Avatar
jovette
Greg
Greg, I suggest you purchase a CLB and carry it with the vette, along with necessary screwdriver to remove the knee bolster, so you can remove the GM recall installed K-Harness, when it fails, and install your CLB. Believe it's simply a question of when, not if, it fails, based on my experience and that of the very vast majority of those on this forum. Just a friendly suggestion.
To Column lock-CLB
