Tire pressure for street use
Old Oct 29, 2001 | 06:02 PM
WHY2KRAG's Avatar
WHY2KRAG
Default Tire pressure for street use
Run flats whats everybody running their tire pressure at for street use (normal Driving) fronts and rears :D :seeya
Old Oct 29, 2001 | 07:45 PM
Viprklr's Avatar
Viprklr
Default Re: Tire pressure for street use (WHY2KRAG)
30 # all around for me. I have heard of some running 28 in the rears and 32 in the fronts. :cheers:
Old Oct 29, 2001 | 09:41 PM
C5Dawg's Avatar
C5Dawg
I run 30 cold which is about 32 at normal road speed.
Old Oct 29, 2001 | 10:09 PM
MelloYellow's Avatar
MelloYellow
27-28 COLD
Old Oct 29, 2001 | 10:33 PM
bparker's Avatar
bparker
Default Re: Tire pressure for street use (MelloYellow)
27-28 COLD
Thats living on the edge, as @ 25lbs you will get a low tire pressure warning on the DIC.. :eek:
Old Oct 30, 2001 | 01:24 AM
mozin's Avatar
mozin
With the colder weather arriving I just pumped my tires back up to 30 psi COLD.
Tom
Old Oct 30, 2001 | 03:10 AM
SRitger's Avatar
SRitger
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
30 all around... :yesnod:
Old Oct 30, 2001 | 07:36 AM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: Tire pressure for street use (SRitger)
Thanks for the tire pressure settings. I will adjust to 30 psi all around :yesnod: :seeya :cheers:
Old Oct 30, 2001 | 08:14 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In VI Veteran
Default Re: Tire pressure for street use (C5-Dawg)
Same here...
Nick
Old Oct 30, 2001 | 09:09 AM
Tom/99's Avatar
Tom/99
30 psi front and rear. :chevy
Old Oct 30, 2001 | 09:30 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
30lbs. at all four corners.
BOB
Old Oct 30, 2001 | 09:37 AM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Make sure that you use winter weight air. :yesnod:
Old Oct 30, 2001 | 10:50 AM
Ben01C5's Avatar
Ben01C5
Default Re: Tire pressure for street use (RedHot)
DO the forum vendors offer this???
:lol:
Old Oct 30, 2001 | 05:02 PM
NCOMNC5's Avatar
NCOMNC5
I just had new tires and rims installed, owner of tire shop said 35 all the way around. I had been using 30 all around and the old tires looked to wear evenly, the rears did seem to wear more in the center of the tires. I don't drive my vette hard and have 30,000 on it (99 vert).
Old Oct 30, 2001 | 07:54 PM
Halls 2's Avatar
Halls 2
32# cold, 35# hot. I like a little higher pressure for improved handling. If the pressure is too low the tire will tend to roll onto the edges and lift the tire face when cornering hard resulting in a sudden loss of traction. I hate it when that happens!
Old Oct 31, 2001 | 02:13 PM
Mark S.'s Avatar
Mark S.
I know that it's recommended 30LBs, but I have always gone with 32LBs (cold) all around and for the most part my tires seem to last and last. :)
Old Oct 31, 2001 | 11:56 PM
Dave68's Avatar
Dave68
Default Re: Tire pressure for street use (NCOMNC5)
That's bizarre that the shop owner would recommend such a high pressure, especially if your rears were showing wear in the middle after running 30 psi.
My manual says 30 and that's what I run.
To Tire pressure for street use
Old Nov 1, 2001 | 03:22 AM
Halls 2's Avatar
Halls 2
Default Re: Tire pressure for street use (Dave68)
Oh surprise, tire guys and car guys disagree on tire pressure! I think that if nothing else we have all learned from the Ford/Firestone fiasco that car manufactures don’t always agree with the tire manufactures on tire model, design, application, and inflation pressure! The car manufacture wants a nice cushy ride and screw tire life and performance. The tire guys want performance, tire life, no tire failure and screw the ride. :smash:
Old Nov 2, 2001 | 03:33 PM
te51cle's Avatar
te51cle
If the centre of your tyres was more worn than the edges and the shop told you to put more air in them I think they're trying to say that they want to see you more often ! Did the owner look like this perchance :troll ?
I think you'd be better off dropping the rears down a pound or two, you should get better traction and tyre life. Whether you get more or less cornering grip is a separate issue that only you can tell though.
Old Nov 2, 2001 | 03:44 PM
YELLOHHH's Avatar
YELLOHHH
Default Re: Tire pressure for street use (te51cle)
30 cold, front and rear for the street.
45 front and 25 rear for the 1/4.
Greg
:cool:
