help... smoked belt
Old Jul 4, 2007 | 02:07 PM
jman1's Avatar
jman1
Default help... smoked belt
just went and started my 97... it was idling fine.. until i turned on the AC... the engine almost died and something around the belt area started smoking!!! it runs fine when the AC is off but as soon as i turn it on it almost kills the engine and it sounds like one of those bottom belts starts to squeek any idea??
Old Jul 4, 2007 | 02:16 PM
Bob CTS's Avatar
Bob CTS
Since the belt is always turning and the only thing that changes with the AC on is the clutch engaging, your compressor might be locking up.
Old Jul 4, 2007 | 02:19 PM
c5rulz's Avatar
c5rulz
Sounds like the place to start.
Old Jul 4, 2007 | 02:41 PM
jon c's Avatar
jon c
Old Jul 4, 2007 | 02:43 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Ouch
Yup, sounds like your A/C compressor has gone to the "Happy Hunting Ground" in the sky. Bummer....
Old Jul 4, 2007 | 04:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is one time I DO NOT have an objection in recommending that you change your AC Compressor! It locked up internally and must be replaced! Most likely due to a loss of compressor oil over time. That would cause it to seize.
BC
Old Jul 4, 2007 | 07:24 PM
jman1's Avatar
jman1
any tech tips???
Old Jul 4, 2007 | 08:39 PM
BanditDude's Avatar
BanditDude
Originally Posted by jman1
any tech tips???
Probably not. You'll want to bring it to a shop with proper tools so they can recover the refrigerant. I "vented" one years ago when the stuff was cheap. It would probably cost much more to re-charge today.
Old Jul 5, 2007 | 01:43 AM
gpracer1's Avatar
gpracer1
Not to mention if it is locked up, then the compressor damage has most likely spewed some of its internal bits throughout the system. After removing the compressor, the whole system will need a good flushing to get any leftover chunks out. Best left to a professional.
Old Jul 5, 2007 | 09:02 AM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Old Jul 5, 2007 | 10:13 AM
TEXHAWK0's Avatar
TEXHAWK0
Isn't there a pressure switch to keep the compressor from engaging if the freon is low?
Also, if the compressor has failed, you may never get all the metal particles out of the system, especially the condenser since that is where most of it tends to accumulate. If you have a compressor failure, it is a good idea to replace the condenser and the dryer along with the compressor to have a chance of the system working trouble-free.
Old Jul 5, 2007 | 10:40 AM
chevy406's Avatar
chevy406
Your compressor is locked. If it were just low freon pressure, then the clutch would not engage at all (with or without the switch turned on). Fortunately for us, the C5 has a separate belt for the A/C. You can replace it at your leisure. It's not that hard to do yourself, but it does take some special tools (vacuum pump, gauges). At the least, you could buy the parts and install them yourself to save some cash.
Old Jul 5, 2007 | 02:32 PM
jman1's Avatar
jman1
is there a procedure for replacing the compressor anywhere?? i searched but didnt find anything....
To help... smoked belt
