Differance in Z06 Suspension vs regular C5???
Old Oct 29, 2001 | 10:26 PM
STEEDAQ's Avatar
STEEDAQ
6th Gear
Default Differance in Z06 Suspension vs regular C5???
What are the differances in a regular C5 vs a Z06? Need specifics if anyone has them.
Old Oct 30, 2001 | 02:31 AM
C5_PIG's Avatar
C5_PIG
Default Re: Differance in Z06 Suspension vs regular C5??? (STEEDAQ)
I've been asking same elusive question and dont' really get any response.
Old Oct 30, 2001 | 11:12 AM
c5vetteman's Avatar
c5vetteman
Default Re: Differance in Z06 Suspension vs regular C5??? (C5_PIG)
Different Sway bars (larger diameter), stiffer springs, and stiffer shocks.
:cheers:
Old Oct 30, 2001 | 11:20 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
What c5vetteman said, plus dont forget Z06 has it's own alignment specs.
Also dont forget the Z06 has wider tires, which the suspension components are likely tuned for.
Old Oct 30, 2001 | 11:37 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Differance in Z06 Suspension vs regular C5??? (kewlbrz)
I called Paul at VB&P and he told me that the spring rates are around 760-800 lbs for the front and I think he told me 600 lbs for the rear (same as Z51). The sway bar in front is a little thicker than the Z51 but uses the same rear swaybar as the Z51. Then there is the 1" wider wheels front and rear and bigger non runflat tires that fit correctly on those wheels. All of it combined makes for an OK package. I went heavier spring rates, T1 Bars, Poly Bushings, and Heavy Duty Tie Rod Ends, Plus Bilsteins. The 02 Z06 has better valved shocks so that the car squats better on the launch. This probably is one of the contributing factors to the quicker times. :cool:
Old Oct 30, 2001 | 11:35 PM
Jacob's Avatar
Jacob
Default Re: Differance in Z06 Suspension vs regular C5??? (Shinobi's97)
In addition to improved handinlg, the Z06 has a considerably more comfortable ride than a Z51 C5 (comparing a 2001 C5 to a 2002 Z06). I suspect most of the difference in ride is a result of the tires (run flats vs non run flats). I found the Z51 C5 to be extremely harsh on bumps but quite comfortable otherwise. My wife almost immediately commented that the Z06 was way more comfortable than the C5.
Old Oct 31, 2001 | 02:18 AM
C5_PIG's Avatar
C5_PIG
Default Re: Differance in Z06 Suspension vs regular C5??? (Jacob)
SPRINGS???? What springs? Do the C5's have springs? Can someone post a pic?
Old Oct 31, 2001 | 02:27 AM
kewlbrz's Avatar
kewlbrz
They are transverse mounted front and back composite leafs. Not coils.
[Modified by kewlbrz, 12:38 AM 10/31/2001]
Old Oct 31, 2001 | 02:54 AM
bdavies's Avatar
bdavies
So besides the wheels & tires, the differences between Z51 and Z06 are:
front swaybar
shock valving
alignment specs (I've read that the only difference is the Z06 has more negative camber)
Is that everything? Has anyone w/ Z51 swapped Z06 shocks & front swaybar and re-aligned to Z06 specs? Just curious if it's much of an improvement handling wise.
Old Oct 31, 2001 | 01:40 PM
C5_PIG's Avatar
C5_PIG
Oh Ok, thanks Kewlbrz.
Old Oct 31, 2001 | 02:13 PM
kewlbrz's Avatar
kewlbrz
No prob. They are just hard to see as they are integrated well and sit in there crossways.
Old Oct 31, 2001 | 04:50 PM
Fast Mover's Avatar
Fast Mover
I would have to disagree, It could be a matter of opinion. I've driven an 01 Z06 extensively and feel that the Z51 suspension felt better for street driving even with the harsher runflats.If on a smooth surface the runflat equipped Z51 is in my opinion more of a refined ride. The track is a different story, the Z06 is better. :)
Old Oct 31, 2001 | 05:21 PM
Sully C5's Avatar
Sully C5
For info regarding the differences check out this link... http://www.corvettemuseum.com/specs/2002/index.shtml
To Differance in Z06 Suspension vs regular C5???
