Need a torque spec!
Old Jul 7, 2007 | 08:24 PM
Scatterbrained's Avatar
Scatterbrained
Default Need a torque spec!
I'm looking for a torque spec! Not sure what the piece is called but...
It has 6 nuts that secure it to the flexplate/flywheel assembly. This is the piece that the propeller shaft slides into, and is then locked into place with a collar that has a single allen head bolt.
Not sure what this is called, so I can't be 100% sure of the spec.
Any help out there tonight? I'd like to get this motor back into the wife's car and running before the end of the weekend!!!
TIA
Scatter'd
Old Jul 7, 2007 | 08:30 PM
vettenuts's Avatar
vettenuts
Do you mean the flex plate? If so there is a torque, loctite and tightening pattern requirement.
Tighten in three passes using GM 12345382 to the threads (I believe the equivalent in Loctite 242 (blue)) and tightening up snug. Use the star pattern to tighten (can't draw it here).
Pass 1: 15 lb-ft
Pass 2: 37 lb-ft
Pass 3: 74 lb-ft
Old Jul 7, 2007 | 11:03 PM
Scatterbrained
Default torque specs...
Nope. The flexplate is already torqued per the manuals, in three steps. This piece actually bolts to the flexplate, six nuts on it, and it rides on the splined shaft that comes out of the torque tube.
Still looking...
Scatter'd
Old Jul 8, 2007 | 04:04 PM
Scatterbrained
Default torque
Anyone???
Old Jul 8, 2007 | 06:21 PM
vettenuts's Avatar
vettenuts
I see something called the "hub clamp", is that what you mean? Any photo's?
Old Jul 8, 2007 | 06:24 PM
Scatterbrained
Default torque
Not the hub clamp... I think I have it.
Old Jul 8, 2007 | 06:32 PM
vettenuts's Avatar
vettenuts
Sorry I'm not much help, I have the manuals but my car is a stick so I am not familiar with the A4 setup.
To Need a torque spec!
