Serpentine belt comes off - '97
Old Jul 8, 2007 | 12:05 PM
ohioblack97's Avatar
ohioblack97
1st Gear
Default Serpentine belt comes off - '97
3 times in the last month the serpentine belt has come off at start up. It is 10 years old. Also have a slight squeel when the car is idling which definitely seems to be coming from the belt. I will replace, but does anyone think that there might be another problem with something out of alignment? Any others have this issue?
Old Jul 8, 2007 | 01:11 PM
shannanl's Avatar
shannanl
Did you check the tension pulley? I just replaced the top one on my 97. It was worn out. My belt did not come off though.
Old Jul 8, 2007 | 01:16 PM
robertp's Avatar
robertp
Had the same problem.Replace top tensioner and belt. No more trouble.
Old Jul 8, 2007 | 02:36 PM
ericdwong's Avatar
ericdwong
Me too, threw the belt at the drag strip, car almost overheated since the water pump is driven by it Replaced the tensioner, no more problems.
Old Jul 8, 2007 | 04:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I highly recommend checking the harmonic balancer pulley and make sure it isn't wobbling or is walking off the snout. It a common problem and will cause belt issues.
BC
Old Jul 8, 2007 | 11:43 PM
torchredfrc's Avatar
torchredfrc
BC
This is very common.
Old Jul 9, 2007 | 01:32 AM
Rich Z's Avatar
Rich Z
If that happens, how difficult is the fix?
Old Jul 9, 2007 | 04:05 AM
BlackZ06's Avatar
BlackZ06
The BELT is 10 years old ???????
The only thing that surprises me is that it has lasted that long ....
To Serpentine belt comes off - '97
