Powerloader Down Shifting
Old Nov 1, 2001 | 03:53 PM
Fast one's Avatar
Fast one
Default Re: Powerloader Down Shifting (ejs1993)
I planned on installing a Powerloader this winter; why can't a milder program become available? If the normal program is too agressive why can't it be set back to take the edge off?
Old Nov 1, 2001 | 04:34 PM
Good2Go's Avatar
Good2Go
Default Re: Powerloader Down Shifting (Fast one)
Correct me if I'm wrong, guys. Milder is available. I believe that would be the Hypertech III!!
Old Nov 1, 2001 | 04:47 PM
COOL Z06's Avatar
COOL Z06
Default Re: Powerloader Down Shifting (Good2Go)
Powerloader II......... :cheers:
:rolleyes: Need to get one! :yesnod:
Old Nov 1, 2001 | 05:55 PM
SilverStar's Avatar
SilverStar
Default Re: Powerloader Down Shifting (COOL COUPE)
I've decided that the Powerloader shifts the A4 like I would shift the M6. Enough said, except "Thank you Steve Cole".
Old Nov 2, 2001 | 12:00 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default Re: Powerloader Down Shifting (SilverStar)
EXACTLY!!!
If you want soft unnoticeable shifts and a tranny that will not downshift, save your money and stick with the stock program. On the other hand, if you want to drive a sports car with an automatic (normally a contradiction of terms), get the Powerloader.
Old Nov 2, 2001 | 03:11 PM
Da Kind's Avatar
Da Kind
Fast one,
Your request: "why can't a milder program become available? If the normal program is too agressive why can't it be set back to take the edge off?"
Now, ask 1,000 different C5 owners to define "milder".
You'll get 1,000 different answers.
Then, pretend you are a programmer and try to fullfill the 1,000 different answers (or driving style).
This is why it is not that easy as a programmer to fullfill your and 1,000 other requests with regard to "the right feel or shift points."
Thanks.
Old Nov 13, 2001 | 11:47 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: Powerloader Down Shifting (Da Kind)
question, does the powerloader remove the lag when you punch it, and the RPM's jump up, but the car doesnt move anywhere, and then downshifts and goes? I hate that.....its that sweet spot at 30 and 55 that I like...but dont care for that delay.....
