Transmission fluid change?
Old Jul 8, 2007 | 08:18 PM
Pewter 01's Avatar
Pewter 01
Default Transmission fluid change?
When should you change the tranny fluid? And how much does it usually cost? Also, the same question for coolant.
Old Jul 8, 2007 | 08:52 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
here is a link for the transmission. Just scroll down until u get the transmission part.
http://www.idavette.net/hib/C5diy/c5diy2.htm
Old Jul 8, 2007 | 08:56 PM
Dave68's Avatar
Dave68
Coolant is every 5 years if you use the OEM stuff. Tranny and diff fluids can go longer, but I changed mine at 30,000 miles. (Amsoil Universal ATF for the tranny and SVG 75W-90 synthetic gear lube for the diff)
Old Jul 9, 2007 | 04:27 PM
Pewter 01's Avatar
Pewter 01
tttt
Old Jul 9, 2007 | 05:04 PM
RB Racing's Avatar
RB Racing
I just had mine changed at 50k. My tranny was starting to leak a bit after sitting all winter so I took it to a local trans shop they flushed it, new fluid, filter and pan gasket and a bottle of Lube Guard additive for only $110. Wasn't worth it for me to jack it up and burn my hands on the exhaust while filling it up.
Trans runs about 10 deg. cooler now and the leak is gone.
To Transmission fluid change?
