active handling issues
Old Jul 9, 2007 | 06:53 PM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default active handling issues
just had avic d3 installed and now have service active handling come up will not go into compedative mode. speed arm also acting up. any idears how to fix without taking it to dealer. dont want to take back to installer he did not know how to fix dont want him to mess it up anymore. also seem to have no power in 5th and 6th gear. will driving it hurt car anymore. its a 01/z06 with 4300 miles on it. have warrinty.
Old Jul 9, 2007 | 08:01 PM
corvettedoug's Avatar
corvettedoug
What code(s) were thrown after the traction control light came on?
Just hold the "Options" button down and press the "Fuel" button 4 times to pull the codes.
It might just be a loose connection agter the install, but it would still help to check for codes.
Old Jul 9, 2007 | 08:30 PM
Bill Dearborn's Avatar
Bill Dearborn
Had to look up what an Avic is but still not sure about the term Speed Arm.
Check your codes as indicated above. The yaw rate sensor for the ABS/AH/TC system is just below the A/C head maybe it was moved or disconnected while the installer had the dash apart.
You will not feel much power in 5th until your speed is above 115 while 6th doesn't feel like it has much anywhere. They are both overdrive gears.
Bill
Old Jul 9, 2007 | 08:45 PM
JAMESNORTHPROV
what i mean the speed dial showed i was going 120 when i was only doing 50, then corrected itself. will check codes in the am and post. thanks. also i think i here a little arking from behind the new radio install.
Old Jul 10, 2007 | 05:36 PM
JAMESNORTHPROV
here are the code #s tcs c1282hc, c1287h, c1288h, and one more in borfa u1064. today the throttle stuck at 3000 rpm for 3 to 5 seconds. any idears, thanks jim.
Old Jul 10, 2007 | 07:59 PM
vettenuts's Avatar
vettenuts
Just had to look up what the Avic D3 is. I have a feeling they tapped into some electrical wires they shouldn't have when they installed it. You can try clearing the codes and see if that straightens it out.
Old Aug 1, 2007 | 05:19 PM
TM-Z06's Avatar
TM-Z06
Did you ever get this resolved? I've been getting the same codes C1287H and C1288H
Old Aug 1, 2007 | 05:34 PM
JAMESNORTHPROV
steering sensor bias fault, steering sensor flaut. you might hav e to change your sensor. i had a bad wire to my yaw rate sensor that the gps installer nicked durring installation. if you have access to a scaner you can break it down moe. good luck. jim
To active handling issues
