Windshield Wiper problem
Old Jul 10, 2007 | 09:52 AM
REW89's Avatar
REW89
Default Windshield Wiper problem
I read the posts here on windshield wiper motor and module problems so I think I know what the problem is. But just be sure.
I was turning a corner and mid turn the passenger wiper blade came up on the windshield while the driver side wiper blade only moved a little. I don’t know if I accidentally hit the stalk but I could have mid turn. Got home, wiggled and positioned the arms, turned the wipers on and this time the passenger side moved up over the driver side arm bending it. The driver side arm hardly moved. Should I assume it is time to replace motor, module, clean udders, replace bent blade, etc. OR is there another explanation I should check. Car is rarely driven the rain.
Thanks in advance for your replies. Bob
Old Jul 10, 2007 | 10:56 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Don't have an answer to your question but lets take it TTT.
Old Jul 10, 2007 | 11:13 PM
REW89's Avatar
REW89
Thanks.
Anyone, anyone
Old Jul 11, 2007 | 04:41 PM
bighank's Avatar
bighank
Default wiper problem
Sounds like the driver side os either off the linkage or something is bent.
Open it up and see what you find. My old chrysler had plastic seats for the linkage which would eventually fail and necessitate a trip to the junk yard (EXCUSE ME AUTO RECYCLING CENTER). Take a look at the linkage. Might just be something OFF the pivot. I removed the drivers wiper about a year ago for another problem and put it back on and tightened it to what I THOUGHT was tight. The arm slipped and I would up tightening it to where I felt it was going to snap any second.
You might just have a loose bolt on the arm. You need to carefully remove the plastic cover at the base of the arm to get to the bolt.
GOOD LUCK BIGHANK
Old Jul 11, 2007 | 06:53 PM
REW89's Avatar
REW89
Thanks. I will try that first. Bob
To Windshield Wiper problem
