TQ question for you number crunchers
Assuming you have insanely good rear traction, how much torque would be required to lift the front wheels of a C5 off the ground from a dead stop?
.I would have figured the required torque would be calculated as follows:
Sum of Torques about the rear wheels = 0 (to get the fronts just off the ground would require in incremental increase in torque)
The only torques that there would be are the weight of the front end times the wheel base and assumming that the rear wheels lock, it would be the Torque that the car has at the rear wheels.
So the torque required at the rear wheels would be:
T = Mass of vehicle x .51 (weight dist) * g * wheel base
Mass of car = 1459 kg
g = 9.81 m/s^2
Wheel base = 104.5 in = 2.6543 m
T = 19,343 Nm (14 266 lb*ft) which is obviously wrong. What am I missing?
Anyone know what the height of the COG for the cars is?
Thanks for keeping me up tonight RadioFlyer.
g = 9.81 m/s^2
I think you're calculating for the total mass of the car. You forgot you you're trying to lift the front part of the car (everyginth in front of rear wheels) and the mass in the rear then acts as a counterbalance.
...oh and you're welcome
g = 9.81 m/s^2
But if you run with the numbers:
g = 9.81 m/s^2
Equivalent mass of a uniformly distributed load = .25 x (1459-150-150-100)=264.75kg
T = 6894 Nm (5085 lb*ft)
Now using an Auto transmission (1st gear 3.06, with a 3.42 gear upgrade) gives:
5085ft*lbs/3.06/3.42 = 486ft*lbs
Too many assumptions, but I bet that's pretty close.
g = 9.81 m/s^2
now wasn't that fun
