Headlight Twilight Sentinel
Old Jul 10, 2007 | 01:40 PM
RedY2K's Avatar
RedY2K
Default Headlight Twilight Sentinel
In a recent thread about de-activating the twilight sentinel, Bill Curlee wrote, "It's an option that can be programmed out of the BCM using a dealer GM TECH II programmer..... The BCM can only be accessed with the GM TECH II."
I just had a new BCM installed by a dealer and now I can't turn off the twilight sentinel. Can the dealer use a GM TECH II to program the disengage feature back in?
Old Jul 10, 2007 | 02:01 PM
rbrtclk's Avatar
rbrtclk
Yes he can, or you can pull #42 fuse under the passengers floorboard. It turns off the twilight function, but leaves everything else the same.
Old Jul 10, 2007 | 02:36 PM
RedY2K's Avatar
RedY2K
Thank you.
Old Jul 10, 2007 | 02:48 PM
timemender's Avatar
timemender
On my C5, I turned off Twilight through the DIC – Options. No BCM reprogramming; No fuse pulling. Am I missing something?
Old Jul 10, 2007 | 05:13 PM
RedY2K's Avatar
RedY2K
No, I don't think your missing anything. My car was like yours until the dealership replaced the BCM. Now I can't disable the twilight sentinel using the DIC Options button so it will need to be reprogrammed.
Old Jul 11, 2007 | 10:23 AM
dougbfresh's Avatar
dougbfresh
Agreed!
To Headlight Twilight Sentinel
