Valve cover spacers
Old Jul 12, 2007 | 12:19 AM
SLPRC5's Avatar
SLPRC5
Default Valve cover spacers
Is there anyone here using valve cover spacers to clear the aftermarket rockers and if so did you have to get longer spark plug wires?
Where do you buy longer spark plug wires?
Sleeper
Old Jul 12, 2007 | 12:28 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Sleeper
Man don't tell me your wires are too short now.
Old Jul 12, 2007 | 12:52 AM
SLPRC5's Avatar
SLPRC5
Not sure until the spacers come in. I was told they might be Didn't think of that If they are were do i get longer ones???
Old Jul 12, 2007 | 01:15 AM
mvvette97's Avatar
mvvette97
How thick are the spacers suposed to be? I have never heard of longer wires
Old Jul 12, 2007 | 01:32 AM
SLPRC5's Avatar
SLPRC5
1/2", glad I didn't go with the 1" ones.I guess they have them for the relocation of the coil packs.
Old Jul 12, 2007 | 11:45 AM
SLPRC5's Avatar
SLPRC5
Never mind, I figured it out...just use truck or suv coil wires, they are a little longer...and can be gotten at the local dealer.
Sleeper
Old Jul 12, 2007 | 10:01 PM
SLPRC5's Avatar
SLPRC5
bump
Old Jul 13, 2007 | 02:39 AM
racetchr's Avatar
racetchr
I have 1/2" spacers to clear my Jesel's, and have no issue with wire length. Using MSD's.
Old Jul 20, 2007 | 12:31 AM
SLPRC5's Avatar
SLPRC5
Are they the same lenght as the OEM wires? My stock wires fit, but close with the kool socks I have on them, infact the one on #4 cylinder in against the oil stick tube and very close to the header. So I may have to go to a longer set.
Old Jul 20, 2007 | 02:17 AM
C5Sweden's Avatar
C5Sweden
Are those spacers really neccessary, I grinded out my valvecovers inside when fitting my Jesels and it seems to be enough clearence when handturning the engine?
Where do you guys get hold of the spacers?
//T
Old Jul 20, 2007 | 02:40 AM
Hool97's Avatar
Hool97
I have 1/2 in spacers and stock length MSD wires not issues.
Old Jul 20, 2007 | 10:01 AM
ArKay99's Avatar
ArKay99
I have Jesel's and hogged my covers out and they clear, but I also bought 1/2" spacers and tried to use them, but the alternator got in the way. On my car I need to reposition the alternator. What are you guys that are using 1/2" spacers doing for this, or do you not have interference with the alternator? Hope this isn't looked at as a hijack, just pointing out the problem I had with my car.
Old Jul 20, 2007 | 11:01 AM
C5Sweden's Avatar
C5Sweden
Ok, I will try without and see. What made you go with spacers since your covers cleared? Just curious.
//T
Old Jul 20, 2007 | 11:26 AM
SLPRC5's Avatar
SLPRC5
My VC is snug under the alternator. I just swang it out of the way and then pushed it back in place....so far it's good.
Old Jul 20, 2007 | 10:20 PM
Hool97's Avatar
Hool97
I initially just used a home made very small bracket to move the first coil. Then I got a bullet alternator extension from A&A Corvette. Its about 3" in extension.
Old Jul 20, 2007 | 11:02 PM
SLPRC5's Avatar
SLPRC5
Do you have any pictures of this?
Thx
Old Jul 21, 2007 | 12:37 AM
ArKay99's Avatar
ArKay99
//T
I had .050" shims under the mounting bars to get a good wipe on the valve tip and the rockers hit the valve cover, even with some serious hogging. I had to go with .025" shims and it clears, but not by much, and my wipe is just slightly wider.
Old Jul 21, 2007 | 04:23 AM
C5Sweden's Avatar
C5Sweden
Is there any aftermarket valvecovers out there, can buy complete ones that is higher and fits with Jesels?
//Tommy
To Valve cover spacers
