Changing spark plugs
Old Jul 13, 2007 | 02:30 AM
Boosted04Z06's Avatar
Boosted04Z06
Default Changing spark plugs
Guys, is there a trick to change the plugs on these cars??? What is the easiest way?
Dustin
Old Jul 13, 2007 | 02:49 AM
NITRO UK's Avatar
NITRO UK
YOU CAN MAKE IT EASIER JUST TAKES A BIT OF TIME.
TAKE OFF ALL THE RUBBER HOSES AIR INJ ON EXHAUST DRIVERS SIDE
TAKE OFF THE BATTERY,THE BAT COMPARTMENT PLASTIC SIDE COVER
DIP STICK,FUEL RAIL COVERS.SOUND CRAZY BUT BETTER IN THE LONG RUN.GET YOURSELF A GOOD RATCHET,S/PLUG SOCKET.SOME EXTENTIONS SMALL 1" 2" ETC .I USE A SMALL LENTH OFF CHROME TUBE (HOME DEPOT) SLIDE IT OVER THE RATCHET HANDEL TO CRACK
LOSSE THE PLUG.USE A TORQUE WRENCH TO DO BACK UP ,I USE A SMALL 3/8th DRIVE T/WRENCH.I ALSO PUT A BIT OFF ANTI SIEZE
GREASE ON THE PLUG THREAD. NITRO UK
Old Jul 13, 2007 | 04:14 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
http://www.amazon.com/Double-Swivel-.../dp/B000HTAXLU
Makes life much easier.
Old Jul 13, 2007 | 10:08 AM
Nyvetteguy007's Avatar
Nyvetteguy007
Originally Posted by BQuicksilver
I use the same tool....great toy...
Old Jul 13, 2007 | 02:47 PM
gto65lvr's Avatar
gto65lvr
I had a 97 that i went from up top and from underneath with no special tools other than sockets, wobbles, and extensions
but of course i dont have fat fingers so it made it a bit easier. Not too bad
Old Jul 13, 2007 | 05:30 PM
EStreeter's Avatar
EStreeter
It doesn't take too much time to remove the components above and the extra clearance makes access to the plugs much easier. You may also want to pull the coil packs - there are just a few 10mm bolts on each bracket and off they come.
Its a pretty easy mainyenance procedure.
Old Jul 13, 2007 | 07:23 PM
MUKAK's Avatar
MUKAK
i do mine from top, with basic tools
Old Jul 13, 2007 | 08:30 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Just make sure the engine is cold
I can get to mine from the top with no problems. It's tough with a hot engine.
Bob K.
Old Jul 13, 2007 | 08:52 PM
Nyvetteguy007
Bob K.
When I do mine its always first thing in the AM with an ice cold engine...I do them from the top with the swivel socket..piece of cake....
Old Jul 13, 2007 | 11:55 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
the essential tools:
1/4" socket wrench
5/8" spark plug deep socket
3" extension
double swivel attachment (for plug #7)
with these, you can swap all the plugs in about a half hour easily from the top. Somtimes it's easier to place the Socket on the extension and place that on the plug before attaching the wrench.
Old Jul 14, 2007 | 12:26 AM
tellefan's Avatar
tellefan
Don't forget anti seize and a torque wrench. Both are much cheaper than pulling a head to re thread a plug hole. David
Old Jul 14, 2007 | 02:10 AM
Scoundrl's Avatar
Scoundrl
That double knuckle tool is the bombdigidie. I used it on my buddies car and it makes the job a total cakewalk. Well worth the $50.
-Ken
Old Jul 14, 2007 | 02:13 AM
Lone_sword's Avatar
Lone_sword
#7 plug=death
Old Jul 14, 2007 | 02:18 AM
2MuchRiceMakesMeSick's Avatar
:LOL: it must take you 3 hours to change the plugs removing all of that stuff
I dont remove any of that stuff. I just stick my spark plug socket with extension and ratchet and go. Ive never had a problem reaching any of them
Old Jul 14, 2007 | 03:32 AM
nastymant's Avatar
nastymant
service manual says 15 ft*lbs for plugs installed in new heads & 11 ft*lbs for replacing plugs. seems kinda low torque..but i guess they know better!!
Old Jul 15, 2007 | 03:27 AM
NITRO UK's Avatar
NITRO UK
1 hour 40 mins on a good day
i have`nt been stock for a while now,so please forgive me.i have never
just done the plugs,i always end up doing other stuff at the same time.
you know (while im here) kinda thing.
i also have a few extra parts in the way of my plugs.
i also found the wires to be a pita to get off,thats when you might need a bit more room just trying to help the guy.
Old Jul 15, 2007 | 03:17 PM
waterzap's Avatar
waterzap
Just be careful with the swivel attachment. You wont be able to torque correctly anymore. Just a normal extension wont matter, but with that thing, you are adding a bit of a lever to the torque wrench. I have the S&K version, with is a bit cheaper. Got it off Amazon for $27. Just do a search for "3/8 In Drive Double Swivel Spark Plug Socket - 5/8 In"
More useful in getting the plugs out than in though.
Old Jul 16, 2007 | 12:07 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Nitro uk - i think i just drooled a little....
Assuming the spark plug threads don't get stripped, are there any hazards of overtorquing the plugs?
To Changing spark plugs
