A/C Problem
Old Jul 13, 2007 | 10:48 PM
Slick Rick's Avatar
Slick Rick
Default A/C Problem
Hi guys this has been a terrible week. First off the drive side differential seal blew. Get that fixed and then the battery goes dead. Charge the battery and now my a/c is blowing warm air out the center vent and cold out the passenger. The battery is getting replaced with a new one tomarrow. Does any body have any ideas as to why this would happen after a battery charge, it was all fine before I took the battery out....I also noticed I didnt hear my actuater resetting. Is there a fuse I can pull to reset it or will it possibly reset with a new battery. Like I said everthing was fine until battery went dead......
Old Jul 14, 2007 | 01:36 AM
frczwannabe's Avatar
frczwannabe
If Its Throwing A Code In Hvac Reset And See If Code Is Still Present, If It Goes Away And Blows Cold Prob Solved, If Not
1. Low On Refrig
2. Blend Door Actuator Is Sticking
Old Jul 14, 2007 | 10:20 AM
ronwc's Avatar
ronwc
You can also try to pull the 27 fuse in the passenger side footwell -
Old Jul 14, 2007 | 03:23 PM
Slick Rick's Avatar
Slick Rick
Hi Guys, Things are good again. After I put the new battery in air conditioner works like a champ, cold from both vents again.....
Old Jul 14, 2007 | 03:37 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sweet!
I have to fix mine because it blows out of all vents no matter where you set the control!
Stuck Actuator - Anyone know how to fix this problem?
Will I have to tear it open and unstick it or what?
Thanks,Matt
To A/C Problem
