Removing Stock Catbacks.
Old Jul 14, 2007 | 10:42 AM
98Artic's Avatar
98Artic
Default Removing Stock Catbacks.
Can anyone tell me if the stock catback (flange rearward) can be removed in one piece without cutting? I would like to save the stock system in one piece, however I am not sure if it can be removed intact without cutting a pipe. (Of course, I am actually talking about 2 pieces since each side is separate. ) Thanks for any information rendered.
Old Jul 14, 2007 | 10:52 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Yes you can remove it without cutting it. You should use a lift because the height needed to lift the rear to get the exhaust out over the axle is dangerous without the proper equipment.
if you do this without a lift make sure you have jack stands for safety. Also you will probably need to add some wood to your jack because most jacks do not have enough extention.
Old Jul 14, 2007 | 12:36 PM
csexton's Avatar
csexton
Took mine off in one piece using a lift. If you have A4, you will need to remove the gas tank heat shield on the passenger side. Good luck
Chuck
To Removing Stock Catbacks.
