I took my rear brakes apart to adjust the emergency brake and all went well on the passenger side but on the driver side the adjuster would not extend although it would turn.
I put all back together figuring i would get that particular part but I would have to buy the whole kit for $134.00 + shipping. So my question is has anyone run into this and can the part #6&7 be taken out and fixed?
Absolutely it can, pry or move the shoe to the side enough to pop out the unit. Be carefull not to pop the spring off behing the shoe. If you do don't panic. Use a notched small screwdirve and a flashlight to finess it back on. Good Luck
