You're killing your engine. Granted, after each event some may say its excessive, but certainly once a year is very bad for your engine. I'd hate to be the guy that owns your car next!
Why in the world would you be so wasteful with oil changes and what is a motive power extractor.
PowerExtractor. The Motive Products Power Extractor™ allows easy evacuation of engine oil, transmission fluid, other vehicle fluids. Also works as a vacuum bleeder. Pumping the integrated hand pump creates a vacuum in the tank and fluid is pulled into the unit through the attached tubing. Comes with dipstick tube for oil changing and stretchable tubing for vacuum brake bleeding. . 10 quart capacity.
Qty: Price: $59.95
Same company that sells the Power Bleeder for brakes and hydraulic clutch systems.
