Squeaking noise from engine bay...sounds like crickets!?!?
Old Oct 31, 2001 | 05:51 PM
carpe dm's Avatar
carpe dm
Default Re: Squeaking noise from engine bay...sounds like crickets!?!? (dsk888)
Probably just a wet belt; should go away with a few more miles to dry things out. :rolleyes:
Old Oct 31, 2001 | 07:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On the old V belt pullies if you had a squeekey belt all you had to do was hit each belt with a mist of water and the offending belt would quiet down until it dried off. That would at least narrow the hunt down to one bad/ noisey belt. Shoot a little bit of water on the belt and see if it quiets down. Sometimes they get dry and need to be replaced. If the belt quiets down , you wiill have the peace of mind knowing that it is only a belt problem and not something more serious..
Sometimes you get a stickey substances on the belt and a little soap and water is all it takes to put an end to the noise.
Belt changes are easy and the belt arn't TOO much money.
Good luck
Bill Curlee :)
Old Oct 31, 2001 | 08:24 PM
95autoLT1's Avatar
95autoLT1
Default Re: Squeaking noise from engine bay...sounds like crickets!?!? (Bill Curlee)
Should be ok after everything dries out :cheers: :cheers:
Old Oct 31, 2001 | 10:50 PM
Pepper's Avatar
Pepper
Sounds like a wife, not a girlfriend.
Old Nov 1, 2001 | 03:32 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: Squeaking noise from engine bay...sounds like crickets!?!? (Pepper)
:D :D :D :D :D :D :D :D
Michael
To Squeaking noise from engine bay...sounds like crickets!?!?
