Header install
Old Jul 19, 2007 | 12:11 PM
speedsk899's Avatar
speedsk899
Default Header install
Ok I am getting ready to do a header swap on my 99 FRC. I was reading through the LS1howto and noticed that they install a new air tube. My headers do not have a hookup for the air tube. Can I remove it and not use it? It also mentions O2 extenders, are those required also? Also to remove the air tube it says that the intake must be removed. Will I need an intake gasket set? Thanks!!!
Old Jul 19, 2007 | 09:50 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
brand LT'S?
intake gaskets can often be reused
American Racing headers do not need O2 extensions
Old Jul 19, 2007 | 10:27 PM
speedsk899's Avatar
speedsk899
they are tpis long tubes
I already bought header gaskets and new stage 8 bolts
Old Jul 23, 2007 | 01:09 PM
speedsk899's Avatar
speedsk899
Now the stock exhaust has two O2 sensors on each side. When I installed the headers and x-pipe I used just the rear ones. I put in a cat-less x-pipe. Did I do that right?
Old Jul 23, 2007 | 01:20 PM
Redvette_22's Avatar
Redvette_22
All the TPIS headers I've seen, and used, have had the air tubes on them. Are you sure they are TPIS and not the "Ebay Headers"??
Old Jul 23, 2007 | 01:22 PM
MattB's Avatar
MattB
I'm pretty sure that the rear O2 sensors are only to tell you when the cats have gone bad. I think you need to plug them into the front, and get a tuner or programmer to delete the rear O2 sensor codes. If the front ones do not reach, you can buy an adaptor to plug the rear sensors into the front's connection. I got mine from LGM.
The AIR tube is part of the emmissions, I'm pretty sure it dumps air in to the exahust when the engine is cold. If you remove it you will get codes/check engine light. I think it can also be tuned out by a programmer.
Old Jul 24, 2007 | 01:23 AM
speedsk899's Avatar
speedsk899
Well now you have me wondering.......what headers come with out the air tubes? Am I going to have a problem with them? I also put a cat-less x-pipe with a borla stinger in. What problems am I going to have? it is looking like I need to extend the front O2 sensor hook ups to reach
I'm sorry I just realized that I had a brain fart......they are TSP's not TPIS's.......Is that any better than the eBay headers that i keep hearing about?
Old Jul 24, 2007 | 01:39 AM
speedsk899's Avatar
speedsk899
Hey thanks, can you get me the web site for LGM, I tried searching for it and came up with nothing
Old Jul 24, 2007 | 03:56 PM
SLPRC5's Avatar
SLPRC5
Yes you can have a tuner turn off all the O2 sensors and also turn the air pump off.
My installer plugged the rear O2 sensor bongs and deleted them. My front O2s are installed and the air pump is working. No codes or CEL.You are correct..the front O2's and air pump work together...
Old Jul 24, 2007 | 06:09 PM
speedsk899's Avatar
speedsk899
Thanks guys. I think I am goign to just pull the air pump out of the car and have the tune fixed. I ordered the O2 extentions and hopefully it will be running soon
Old Jul 26, 2007 | 06:25 PM
speedsk899's Avatar
speedsk899
I started her up today and see sounds great! I can't wait to be able to drive her!!!!!
Old Jul 28, 2007 | 12:10 AM
speedsk899's Avatar
speedsk899
I am guessing that this is going to sound stupid but someone told me that there is a way to properly bake a set of ceramic coated headers so that they will last longer......has anyone else heard of this?
To Header install
