Lug nut question
Old Jul 20, 2007 | 08:42 AM
bgames's Avatar
bgames
Default Lug nut question
Can someone in the know please tell me whether it is acceptable to use the lug nuts for a 2001 OEM Alcoa Z06 rim on a 2004 Z06? If so, what is the proper torque?
That video of the RX-8 with all four wheels flying off at the same time has me paranoid.
Thanks. Jason
Old Jul 20, 2007 | 09:20 AM
jon c's Avatar
jon c
I believe that car started with NO lugnuts, even if they were loose there is no way that they would all fall off at the same time like those did.....
Old Jul 20, 2007 | 05:22 PM
DDNZ06's Avatar
DDNZ06
That was a awesome video.
Old Jul 20, 2007 | 07:21 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I didnt see it...where is it?
jeff
Old Jul 20, 2007 | 07:23 PM
ZeeOSix's Avatar
ZeeOSix
Thanks. Jason
I would say the lug nuts are the same size and seat angle. I believe the torque is 100 ft-lbs. Check you Owner's Manual ...
Old Jul 20, 2007 | 08:24 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The lug nuts are the same. To ease your mind take one of the lugs and place it in the wheel stud opening. Check seating of the lug. It should have the same seat angle and make contact over the entire surface. Torque settings are 100FT Lbs.
Old Jul 20, 2007 | 09:48 PM
DerekT's Avatar
DerekT
jeff
Quick youtube search and I found this:
http://www.youtube.com/watch?v=vnwf2JWcgg8
Rx 7 wheels fall off, such a shame that is a cool car I have always wanted to do a LSx swap into one of those.
As for the lug nuts, you will be fine with those. The owners manual says 100 ft/lbs but I usually set mine at ~80 ft/lbs.. but that is just me
Old Jul 21, 2007 | 06:07 AM
JeffC5's Avatar
JeffC5
Thanks for the video link. What a way to remind everyone to check the torque on their lug nuts.
jeff
Old Jul 21, 2007 | 07:34 AM
AU N EGL's Avatar
AU N EGL
That Video is a quick reminder too all of us as to not be disturbed or keep to our pre-event check list before each run. Spend too much time talking to buddies and you forget something.
stick with a 100 ft lbs, I have seen lugs come loose at less then that.
Old Jul 21, 2007 | 10:30 AM
Ranger's Avatar
Ranger
I agree. I don't visit while installing wheels or doing my pre-race routine. Distraction yields errors.
The stock C5 Z06 lugnuts are interchangeable year to year.
100. put on as 40, 70, then 100 in a three step process, tightening in a star pattern.
Ranger
Old Jul 21, 2007 | 10:36 AM
Ranger's Avatar
Ranger
jeff
Here is a comment left on that youtube vid:
"He was sold the wrong size lug nuts. Checked after the event, they would torque down but with a lateral load they would jump threads."
Ranger
To Lug nut question
