looking for help!!!
thanks!!!
2. Insert a flat screwdriver blade into the slot in the sunshade inner bezel.
3. Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages)
4. Push up on the sunhade and continue rotating the sunshade outboard until the sunshade disengages fom the mounting bezel.
5. Disconnect the electricall connector.
6. Remove the sunshade.
