Weird CLB problem; PLEASE HELP
Old Jul 20, 2007 | 09:45 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Weird CLB problem; PLEASE HELP
OK I was taking my interior apart to send to C5KIDD and noticed that it looked like my CLB was unhooked and the factory wires were plugged back in so I unplugged the factory wires and plugged my CLB in. Started the car and my steering wheel was locked So I plugged the factory wires back in and the wheel was unlocked but everytime I start the car it says "Service Column Lock". I can just hit reset and everything is fine but how can I get it where it wont come on at all ? Thanks
Chris
Old Jul 20, 2007 | 09:47 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
did you use the adaptor to unlock the mechanism first??
If not...re-connect the stock harness lock the wheel..use the adaptor to unlock it and install the CLB....then it should be fine..
Old Jul 20, 2007 | 09:53 PM
Corvette-Chris
St. Jude Donor '08
I have the stock harness connected now and it doesnt lock but maybe once every few months and I know how to get it unlocked.
When I installed the CLB a few minutes ago it locked.
Old Jul 20, 2007 | 10:26 PM
pewter99's Avatar
pewter99
well damn....I know there was something about pulling fuse 25 in the passenger floorboard to clear the codes after install but....the last one I did I had a similar problem and fixed it by doing what I told you. I wonder if that CLB is bad.
Old Jul 20, 2007 | 10:29 PM
Corvette-Chris
St. Jude Donor '08
Im not sure buts its sure strange. I guess I should have just left it alone since it didnt lock up very often at all. I may try to pull #25 in the morning and see if it will reset
Old Jul 20, 2007 | 11:22 PM
pewter99's Avatar
pewter99
well if the CLB doesnt work you really didnt accomplish anything....
I guess you can call whoever you got it from and ask for help / suggestions
Good luck
To Weird CLB problem; PLEASE HELP
