try pulling the fuse first and see if that's the problem.........just the lights???
Yep all the interior lights...the display/AC/radio...
the left blinker is blinking spontaneously in the front and the right doesn't blink; back lights are fine.
p.s. gorgeous....great job on the engine paint job (your avatar, if it is really your car)
Check the fuse, then check the grounds.........loose wire???
i will...after i finish a few chapters on vascular surgery...
next week- that is what i am doing...have to review everything before i am told to amputate a leg
so the right is blinking quick and the left blinks fine? put a bulb in teh right front...
or better yet have someone put a bulb in.....I don't think you're capable of vehicular surgery..
interior lights and voltage drops are common in C5's with turn signals....our charging systems ain't the greatest
that would be a no brainer punk!! try re reading the post
the left is blinking quick (but the bulb works)...and the right doesn't blink at all...all the interior lights are flickering...
it's like the car is having multiple orgasms, and you can't stop her...
Yo Nip, based on the frequency of different women you have & had in the Vette, I think the on/off switch is just sticky..... use some interior cleaner/disinfector on the switch and/or just wash your sticky fingers before operating machinery
