Any Ideas? Need Help!
Old Nov 1, 2001 | 11:18 AM
Iam_Chief_Wiggum's Avatar
Iam_Chief_Wiggum
Default Any Ideas? Need Help!
Driving to work. Normal commute, 75mph. No spirited driving.
Car started misfiring on the HWY. I checked the codes: PO300. Also a MAF code. I checked connections to: MAF, MAT, Fuel Injectors, Sparkplugs & wires.
All looked good.
Took to shop, all but the #8 cylinder plugs dry. The "reduced engine power" was not lit, so I wasnt sure if this was the cylinder that gets knocked out in limp mode...wondering if "limp mode" only happens when this message is lit.
Anyone have any ideas what the source of the problem could be???
No mechanical sounds, like broken valve springs or bent pushrods. I suppose I'll know more when the guy checks compression and the ignition pack on the #8....
Old Nov 1, 2001 | 12:09 PM
Iam_Chief_Wiggum
Default Re: Any Ideas? Need Help! (Iam_Chief_Wiggum)
any techs on-line this morning? C4C5 Tech? would love the feedback....
Old Nov 1, 2001 | 04:20 PM
Iam_Chief_Wiggum
Broken Valve spring. Again. Jeez. What the heck type of spring did ProAuto Tech use in their packages, anyways???
OK.
Whats the difference between dual valve springs and replacements?
I see comp cams has a new (stronger) part out there...is it a decent replacement? Comp Cams #26918-16
Old Nov 1, 2001 | 04:47 PM
Dave68's Avatar
Dave68
Hopefully, there is no spring-binding going on. My 68 once dropped a valve after the spring broke (not enough clearance at high RPM). It sounds like the shop that installed those springs need to figure out what they did wrong.
Old Nov 1, 2001 | 05:10 PM
Iam_Chief_Wiggum
Default Re: Any Ideas? Need Help! (Dave68)
Its at a different shop.
I have heard that a few people have had problems with springs in higher-lift
motors. I was hoping to hear from someone as to, or if there is a "Better choice" spring for a cam with a lift of, I think, 0.559.
Bueller?
To Any Ideas? Need Help!
