HVAC air blower replacement
Old Jul 22, 2007 | 01:15 PM
kg54trains's Avatar
kg54trains
Default HVAC air blower replacement
Used the forum's search engine to look up this subject. A prior thread had a web site that provided a complete picture description that included the removal of the glove box in the processs of replacing the blower motor for the hvac system. DOES ANYONE HAVE THIS SITE ?
Old Jul 22, 2007 | 02:29 PM
ericdwong's Avatar
ericdwong
I don't but you don't have to remove the glove box to do it. Just pull off the panels underneath and then the blower motor comes out with 3 bolts. Make sure you disconnect the wire harnesses and hoses.
Old Jul 22, 2007 | 11:37 PM
kg54trains's Avatar
kg54trains
It was a breeze with all that room. I also took out the relay that is above the motor next to the fire wall. I also was able to clean up the box and all the other items in reach once the box was out. Huge amount of dust. Box was easy to remove just forgot the reverse
Old Jul 23, 2007 | 09:57 AM
bighank's Avatar
bighank
Default blower motor
Don't forget to replace the air hose on the motor and the dash cowling. It is used to cool the motor. BIGHANK
To HVAC air blower replacement
