HVAC head unit
Old Jul 22, 2007 | 08:09 PM
waterzap's Avatar
waterzap
Default HVAC head unit
What exactly is the HVAC head unit ? The thing under the radio with the lcd and ***** where you set the temp etc? (dual control). Is there anything else that controls the temp? Have the old hot air cold air problem.
Added R314.. installed new actuator...re-indexed new actuator. For the record, the new type of actuator can be taken apart, no screws, but has 4 clips. Also has fewer gears.
When the systems blows cold air, all is good, but as soon as the system starts mixing hot air to keep the temp at a certain level, goes all nuts, and the only way to fix that is stop the car and reset the AC system.
B0361 and B0441 and funnily enough the radio constantly gets U1016
Only thing that works 100% is just keeping the temp on 60 deg manual, and not touch the temp controls.
