Coolant Surge Tank question
Old Jul 23, 2007 | 12:51 AM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Default Coolant Surge Tank question
I think i have a leak in my coolant tank. Is it possible to pull the tank without draining the radiator. Or will there always be some coolant in there? I have a leak but my coolant temps are normal. So i am thinking it's in the surge tank or one of the hoses going into it.
Old Jul 23, 2007 | 10:15 AM
EStreeter's Avatar
EStreeter
The coolant over flow is fed by a single hose at the top towards the back near the battery. The tank has a sealed pressure cap so there is other outlet. If you remove the hose from the tank and hold it higher than the radiator there should be no mess or run out from the radiator. If your tank is full there could be some spillage from the hose outlet so cap it to keep everything dry when you take out the tank. Probably would be a good idea to siphon out the tank first.
I noticed some coolant on the edge of my tank where the black top meets the clear bottom a few weeks ago. I thought the tank was leaking but it was actually the hose connection at the tank. I removed the spring clamp and replaced it with a strap clamp - no more leaks.
Old Jul 23, 2007 | 10:38 AM
PUREFUN's Avatar
PUREFUN
Thought the problem might be connected to my coolant tank but i drove it last night and temps were okay once again. Does the radiator keep a small amount of coolant in the surge tank at all times? If it doesn't than i guess i will have to look someplace else for the leak? Hard to visually verify if there' coolant in the tank and i haven't added any since i noticed the leak.
Old Jul 23, 2007 | 11:17 AM
EStreeter's Avatar
EStreeter
The tank has a line mark on the clear bottom portion in the front that is the proper fill level. The tank should always have fluid in it to that line.
The tank is not an over flow but a pressurized part of the cooling system for expansion when hot - it has a pressure cap and should be sealed.
If you are loosing fluid in the tank and there are no obvious leaks, puddles of coolant under the car and the cap is tight and sealed, then you could have a more serious problem like a blown head gasket. Coolant may be leaking into one or more cylinders and being burned with the fuel mixture. If its not a bad leak, you might not even notice it except for the constant need to refill the coolant expansion tank.
Old Jul 23, 2007 | 09:24 PM
PUREFUN's Avatar
PUREFUN
Definitely has a leak and has a constant drip. Visually can't see anything from under the surge tank. But i am going to pull the tank now and hopefully it's surge tank related. Otherwise because of the turbos everything is going to be hard to get at Have ramps and checked underneath but still really no room to see anything I'm definitely no mechanic but i am hoping it's something i can attempt on my own
Old Jul 23, 2007 | 10:02 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I just replaced mine when I discovered the small line from the upper area of it, had a hairline crack in it. They only cost $50 new. I used a turkey baster however its spelled and removed most all of the coolant from it before removing it totally. It was a pain to do that way, but it wasn't so messy.
Old Jul 23, 2007 | 10:52 PM
waterzap's Avatar
waterzap
And fill it up correctly....
http://www.imcool.com/articles/antif...l-macs2001.htm
1. Keep the cooling system filled. In fact, fill the reservoir bottle to “Hot” level when the system is cold. Problems arise when a system’s coolant level is not maintained. (Fleet vehicles receiving regular maintenance, and with reservoirs kept slightly above normal, do not show signs of contamination. This even applies to the specific “problem” vehicles.)
Old Jul 24, 2007 | 01:59 AM
PUREFUN's Avatar
PUREFUN
Will it's nothing to do with the surge tank or the hoses. Definitely drips in that area though underneath. Looks like i am going to have get it up on a hoist so i can really see underneath. Thanks guys
Old Sep 17, 2007 | 10:31 AM
jedblanks's Avatar
jedblanks
If you are loosing fluid in the tank ....Coolant may be leaking into one or more cylinders and being burned with the fuel mixture. If its not a bad leak, you might not even notice it except for the constant need to refill the coolant expansion tank.
Sorry to dredge up the old thread, but is this a common problem with C5s? I'm having similar issue (loosing coolant, no signs of it on the ground).
In all other cars, when loosing coolant through a head gasket it normally ends up in the oil. Would this not also be the case with the LS1?
I haven't verified the cap is sealing tight and I guess the surge tank/hoses could be leaking only under pressure....
Old Sep 17, 2007 | 10:59 AM
TEXHAWK0's Avatar
TEXHAWK0
I don't think it is a common problem for coolant to dissappear and not know where it is going.
If there are not obvious leaks aroung the tank, radiator or hoses, I would start looking at the water pump. Check the weep hole on the bottom for signs of coolant deposits. It can drip from the water pump, hit on other parts of the suspension or frame, and make it hard to tell where the source is.
Old Sep 17, 2007 | 12:43 PM
Oldvetter's Avatar
Oldvetter
You need to fix any leaks in coolant system ASAP. Dexcool gets thick and muddy in the presence of air (as in a coolant leak).
To Coolant Surge Tank question
