4th Gear Question
Old Jul 23, 2007 | 04:36 PM
Javi1782's Avatar
Javi1782
Default 4th Gear Question
When in shift into 4th Gear in High RPM the gear grinds but if I let the RPM's fall and then shift it dosent grind at all does that mean that 4th gear syncro is bad? I have a 6 speed pretty obvious I guess....
Old Jul 23, 2007 | 05:02 PM
LoneStarFRC's Avatar
LoneStarFRC
Sounds like you're on the right track unfortunately.
Old Jul 23, 2007 | 05:25 PM
Oldvetter's Avatar
Oldvetter
You can try changing your transmission fluid, worked for my 6th gear grinding. These transmissions are sensitive to dirty fluid. I find that I must change mine every 50,000 miles and I use synthetic (currently Amsoil).
Old Jul 23, 2007 | 05:59 PM
see5's Avatar
see5
There is a service bulletin relating to <2001 cars with aluminum shift forks. If you play your cards right you might get a freebie. PIP#3020
Old Jul 23, 2007 | 06:16 PM
Javi1782's Avatar
Javi1782
Thanks for all the responses I kinnda figured it was the Syncro but I will try the fluid and while im at it ill change the differential fluid as well.
Old Jul 25, 2007 | 09:53 PM
shawn copella's Avatar
shawn copella
I have changed shifters and tranny oils, no luck at all.It still grinds going into fourth gears. I am looking for somebody in the Bufalo, N.Y.
area to remove and replace the tranny so I can send it to RPM Transmission. I want it to be a number matching car.
Old Jul 26, 2007 | 06:10 AM
see5's Avatar
see5
Matching numbers on a C5?
Old Jul 26, 2007 | 09:35 AM
robvuk's Avatar
robvuk
Mine grinds when I make fast shifts while cold. Normal shifts or fast shifts after it's hot, seem to be fine. I think I might try to change the oil to see if that changes anything.
To 4th Gear Question
