Can someone post the MN6 washer mod ?
I'm not saying that the fork pads will wear through if you remove the detent, I'm just saying that the fork pads will have accelerated wear due to any small force constantly applied to the shifter while cruising (like resting your hand on the shift ****). My car, to my knowledge, had never had the detent messed with prior to me rebuilding the transmission, and all of the plastic fork pads showed more wear than I was comfortable with, and that's on a transmission with mostly easy street miles.
I replaced my fork pads with bronze ones while I had it appart.
It is only my opinion that removing the detent will cause accelerated fork pad wear, but I challenge anyone to prove me wrong with facts or data.
The detent will also keep the tranny in gear when there is no load on the transmission (ie. when letting off the gas to coast, or stepping on the gas from coasting). I had my detent backed out for a while and the tranny never popped out of gear, so I don't see that being much of an issue, but it could happen I guess.
My detent is now back in and will stay that way.
I have a B&M shifter and find it to be as many do a bit notchy. I'm thinking that if i can get this thing to shift a bit smoother I'll be able to row the gears much faster and easier. Anyone do this mod with a aftermarket shifter like the B&M?
Not having a clue about trannys you guys are all talking over my head. Can this mod be used on a stock shifter to take away the horrible shifting characteristics? If so what size washer should I use?
Yes. 20mm oil pan bolt washers.
The detent keeps the shift rod locked in one fixed position where the loads on the fork pads will be at their smallest, when the shift fork is at rest with the transmission in gear. Removing this interaction between the detent and the shift rod allows small external forces (like resting your hand on the shifter while cruising) to apply a constant load to the fork pads, which will wear them out over time. This will damage the fork pads, and once they're worn right through, also require the replacement of the shift forks as the hardened slider rings will eat right through them.
Use a shifter you like with the detent screwed in.
My $.02.
I'll test my theory once I do this mod given I have a 4th Gen F-Body in the garage next to the vette.
Just my thoughts, no factual data or anything to support.
With the heavier detent only being on the C5, could it be that this is strictly to keep the car in gear during dynamic braking loads when there is no direct load on the transmission? Maybe the ABS pulses are enough to pull the tranny out of gear with the clutch pedal pushed in? This would be a factor over the F-Body for two reasons, one being the extra weight of the shift linkage, and two being the higher braking forces the 'Vette can generate.
I know one thing is for sure, that with the external detent removed the shifter feedback turns vague... no real indication that the car is even in gear when you move the lever. This is why I say that, without the external detent, pretty much ANY load on the shifter will cause wear on the fork pads. I just thought I'd put it out there since I cruise with my hand on the shifter all the time, and with the detent removed I could actually feel the load I was putting on the tranny.
Just thought I'd throw it out there for those who were interested.
I don't advocate removing the detent spring only reducing the pressure by using the washer modification.
I did this the other weekend on my brothers FRC in combination with a C6 Z06 shifter modification. This combination works well. There is postive engagement and locking of the shifter into each gear.
By keeping your hand on the shift **** you cause excessive wear of the shift forks and gears.
5th, but less effort and notchiness.
It's gotta be there for a reason! Thanks for saving me from tearing my tranny up uneccessarily!!!!
My $.02.
Thanks for the info
So far no complaints. I already have 135k on the trans and motor and probably 4,000mi with this mod, so if anything fails in the tranny, I can't really blame it on this specific mod.
Don't have the cheap plastic fork pads, as I had my tranny upgraded by RPM.
Also you are not suppose to hold onto your shifter with any car as that will grind down your forks. If you this, it doesn't matter whether you did the mod or not you're going to grind down your forks.
