Your bolts probably have a ton of lock-tite on them. I don't envy your frustration.
You've may have tried this already. But, despite the low-tech nature, I just make sure I have enough under-car clearance (i.e., car's up high on jack stands or a lift) and use a stout breaker bar for lots of leverage. (Sometimes, leg-power is required vice my arms to get the bolts loose.) Seems to work better than most impact wrenches for some reason.
Good luck with things!
p.s.--Go Air Force! Semper Fi too!
Reason: misspelling of a word
Thanks kedvesh.......I actually have it about 2 feet in the air on jackstands right now (doing a clutch swap) I'm just a little nervous about jerking the car around too much with it on the stands (and me under it)
Thanks for the advice!
Anyone else have any magic that I can try?
I used a piece of pipe on the end of my breaker bar as a cheater. Worked great
