Turn Signal Light Bulb Replacement
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
I remove the black plastic 3 phillips screws, still to hard, removed the top painted cover, 4 torx screws, ahhhhh how easy is that. my preferred way. Ya find the little tab to squeeze, it squeezes very easy. Ya change both while you are doing this. Look at the picture of the bulb socket and the tab to squeeze.
When you remove the top painted cover, you don't need to have the headlights in the up position.
First:
1. Jack up car and support front up with jack stands or wheel ramps (I used ramps).
2. Remove lower plastic panels directly under in front of the front wheels behind corner spoilers. 5 screws, real easy here. (you may have to move the front brake duct tube a little or just work around it)
don't forget to pinch the plastic to unscrew the bulb socket, it's a bi*&h..
3. Reach in and unplug the larger bulb housing with the duel element (Amber 3157), replace and re-install.
4. Remove the smaller side light (197) and swap and re-install
5. Replace and test lights... Only took about 30 mins.. Not to bad..
Good luck.... There is a picture of the process for removing it in this forum,
http://forums.corvetteforum.com/c5-t...-burnouts.html
While you're at it, change both and you won't have to worry about them again for a while.
