Vibration on Idle in Drive or R
#61
The alternator from France was in a GM box.
In fact, I have not found a single marked part yet on the car that shows made in USA.
Gauge Cluster says Japan
Wheel well liners show Canada
Ignition Switch shows Great Britain, the list goes on...
Have not checked belt tensioner yet.
We might be stumbling onto something here..
Tell me if yours is an automatic, and check the tensioner see if it bounces up and down when the noise is happening, and gas it a little .. if it stops ... than ... we can continue.... the alternator from France has me intrigue..
#62
I only have 37,000 miles, but 8-years is a long time I would guess for a tensioner to hold it's spring!
#63
Look at your tensioner & let me know if its bouncing up and down (when its making the noise)
Let me know when you gas it a bit... does it stop
#64
I will try again tonight - it may just be shy and won't do it with the hood up.
#65
I have this same exact problem
#67
Just installed new tensioner, idler pulley and Gatorback serpentine belt - just to see if that might not be part of the problem with my voltage dropping momentarily when coming to a stop. No difference. Apparently my old belt, tensioner and idler were performing fine.
Very slight movement in the tensioner arm at idle which is normal.
#68
got the same problem on my 03. She would stutter and shake after a drive at a stop light and also with the ac on on reverse. I vote for the alternator. Going to the dealer (under warranty) next week to check it out.
#69
Already replaced my alternator with a new GM unit last month, also replaced battery and ignition switch. Still dropping voltage when I come to a stop.
#70
Check the connection and the battery. My voltage would drop after i put in a new battery and realized that it was a bad battery. The 2nd time, my connection was loose. Good luck.
#71
Hi There:
Wow! your car has really low miles. 4k on the clock & 8 years as a garage queen.I would rule out the alternator as the problem. Because of the low miles I would be checking the fluid level of the a/t transmission & shifting plate for security or being bent.All your drive & a/c belts have long exceeded their self life. I would inspect them for weather cracking & change all of them, then you will at least have a good starting point if the problem still persists.Next I would be looking at the belt tensioner.
robsc501
robsc501
#72
Motor mounts / Aged
Hello people...
MY Vette has a problem..
When press the brake and select DRIVE without take off my foot from brake, feels vibration, I think in rear part if I select "N" dont feel the vibration, select Reverse and feel again..
So When Im with brake and Drive or Reverse without moving, feels the vibration...
The car has only 4K miles and never en race track or even street racing, just a few accelerated uses..
The car was in garage most of the time from the last 8 years (Is 1998)...
What do you guys think?
And I would like to thank you guys for all post I've read and learned from. But there have been quite a few I tried to comment on where problem seemed obvious but was sent to set up acct and just never took time.
One post on here i remember was a guy with a manual with a bad vibration and believe it didn't do it until he had new clutch installed. And his clutch didn't last long and shop had him return it but not sure what happened from there. But it sounded like someone left a dowl pin out and I'm sure the shop would never admit it.
#73
Received 19,455 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
#74
correction
Just saw your posting on Vette noise. My noise only occurs at low rpm at 500 or below. How did you ever resolve it? thanks
