Which shocks for Autocross?
Old Aug 30, 2007 | 06:44 AM
  #41
Brodiemans's Avatar
Brodiemans
Originally Posted by Gordy M
For autocrossing/HPDE the C5 Z06 shocks for 2004 have better valve damping than earlier shocks and the C6Z shocks. This is especially true in higher speed transitions and chicanes. The Koni shock would be a slight upgrade from the 2004Z. More important is the alignment, corner weights and wedge. Just changing shock and lowering the car will not give you optimum handling.
See now I heard the dampening was revised in the C6Z shocks after 2006 giving it the same characteristics as the 2004 C5Z shocks, but they were slightly stiff and a larger piston diameter making them an all around better set up
