How to lock flywheel
Old Jul 27, 2007 | 02:28 AM
sigma6's Avatar
sigma6
Default How to lock flywheel
Replacing clutch, need to remove pressure plate bolts but the flywheel keeps spinning. What do you guys use (besides jamming a screwdriver in)?
Old Jul 27, 2007 | 10:38 AM
1-BAD-C5's Avatar
1-BAD-C5
put the car in gear,.. a large prybar jammed up between the tunnel and the teeth of the flywheel. Trust me it wont move at all! its the easiest way.
GOOD LUCK!
Old Jul 27, 2007 | 11:18 AM
kromberg's Avatar
kromberg
Use the Kent Moore flywheel holding tool. Best $100 I have spent.
Keith
Old Jul 27, 2007 | 11:33 AM
HP_Addict's Avatar
HP_Addict
Screwdriver works fine. Not sure how putting it in gear will help, since the drivetrain has been removed to access the PP bolts.
Old Jul 27, 2007 | 10:14 PM
CTSV OWNER's Avatar
CTSV OWNER
The last time I had to tighten a crank bolt I put rope into the spark plug hole. It worked great and no risk of screwdriver scratches.
Dave
Old Jul 28, 2007 | 12:00 AM
TLewis4095's Avatar
TLewis4095
Simple flywheel tool. Less than $25 at most parts stores.
Old Jul 28, 2007 | 08:56 AM
cruisemon's Avatar
cruisemon
That would work better than rotating the engine so #1 is at just before top dead center, pulling the spark plug and filling the combustion chamber with STP and replacing the plug. Don't ask.
Charlie
Old Jul 28, 2007 | 10:48 AM
zbest4me's Avatar
zbest4me
Charlie
ok you got me..........have to ask....WTF?
Old Jul 28, 2007 | 10:54 AM
DIXZ's Avatar
DIXZ
Yea.. it's the first time I've heard that one! Thanks for sharing.
Old Jul 28, 2007 | 01:54 PM
cruisemon's Avatar
cruisemon
uh uh. Let's just say that STP is non-compressible so if the combustion chamber is full and you try to rotate the piston into it, the crank won't turn and you can loosen the flywheel. The rope mentioned above does the same thing but comes out a LOT easier than STP. And that's all I have to say about that.
Charlie
Old Jul 31, 2007 | 12:45 AM
Brad@RevXtremeAutoSports's Avatar
GOOD LUCK!
Old Jul 31, 2007 | 02:42 PM
hotwheels57's Avatar
hotwheels57
I like tools. I like finding excuses to buy more tools. I like using the correct tool for a project. I don't like using the wrong tool which might damage other parts. I don't like having the wrong tool failing or hurting me at the most inopportune time during the project.
Tools can be purchased or you can borrow the correct tool at most auto parts stores.
I use this type of tool to lock the flywheel.
Old Jul 31, 2007 | 05:51 PM
TLewis4095's Avatar
TLewis4095
Thats it! Not to pricey either.
Old Jul 31, 2007 | 08:49 PM
vettenuts's Avatar
vettenuts
That's what I used. Also helpful to spin the flywheel while tightening since there is a pattern that requires it be spun in the process. A real pain but easier with this tool if you are working alone like I was as it can all be done from under the car. For tightening, I would rotate the flywheel (for the pressure plate) and then wedge the tool handle against the floor so I could focus on tightening the bolt to the correct torque value. Almost brought back my muscle tone (not!!!)
To How to lock flywheel
