ARH Header honest install time
Old Jul 27, 2007 | 12:17 PM
MotleyDrew's Avatar
MotleyDrew
Default ARH Header honest install time
Hey boys
Just trying to budget my time needed to do this and was wondering what a realistic timeline for installing these headers is. I have 1 7/8ths headers. Is there more to the install than what the directions say? Is this doable with jackstands or is this a hoist job.
let me know
Old Jul 27, 2007 | 12:25 PM
rpm462's Avatar
rpm462
Old Jul 27, 2007 | 12:48 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
2.5 hours but we have done a few..
Old Jul 27, 2007 | 01:28 PM
MotleyDrew's Avatar
MotleyDrew
I don't believe you I have watch the old Vette Doctors video a bunch of times and it takes them seconds to get them in but with my luck and knowing how you pros make everything else look easy I am worried this could take the better part of a day.
Old Jul 27, 2007 | 01:35 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
I did them on jackstands, I did not get the Bam they're in, but it was not that bad. I did remove the starter as well. Both sides from the bottom.
Old Jul 27, 2007 | 01:37 PM
Cruise-In V Veteran
if you want I would be happy to explain a few easy tricks if you want to call...
Old Jul 27, 2007 | 02:39 PM
MotleyDrew's Avatar
MotleyDrew
Thanks a bunch Chris !!!! Nice talking to you again
Old Jul 27, 2007 | 03:54 PM
rpm462's Avatar
rpm462
Anything you can post on here when you get time?
Old Jul 27, 2007 | 04:08 PM
Marcs c5's Avatar
Marcs c5
This would be great!!
Old Jul 27, 2007 | 04:11 PM
MotleyDrew's Avatar
MotleyDrew
Chris just told me the following would help:
watch for battery cable as not to slice it on passenger side
Unbolt steering arm
Loosen motor mounts
take starter off
and remove coolant temp sensor
he said that it is even more of a bear as I have a LS2 403 and that they will go but everything is a tight fit
Old Jul 27, 2007 | 04:18 PM
Geneus's Avatar
Geneus
Unbolt steering arm
Loosen motor mounts
take starter off
Chris forgot to mention using the Vaseline. j/k
They probably have more experience with installing the ARH system than any shop in the country...they did mine.
Old Jul 27, 2007 | 07:04 PM
MotleyDrew's Avatar
MotleyDrew
will KY work?
Old Jul 27, 2007 | 08:30 PM
BIG ATLANTA's Avatar
BIG ATLANTA
I did mine in about 6 hours the hardest part was 1) getting in/out the drivers side plug near fire wall 2)getting the passenger side header in I tried from above and below removed the starter and the valve covers it eventually went in from underneath but took a good hour. I am not mechanically inclined I took my time fired up and no codes!!
Old Jul 27, 2007 | 08:38 PM
bbob67's Avatar
bbob67
I am installing mine as i post....driver side went in no problem. I actually placed the header up from underneath and then pulled it up and placed it in position from the top. Passenger side is a bit!@%*. Still working on it. Tried to position it as i did on the driver side...no luck. Loosened the motor mount on the p-side...with the starter out and ground cable disc. and motor jacked up on p-side still no luck. Will try again t-morrow with both mounts loose and jack up motor again...hope this will be the ticket. About 3 hrs. so far with removal of the old system.
Old Jul 27, 2007 | 09:08 PM
Just Enough's Avatar
Just Enough
I put the ARH 1 7/8th in and they aren't any fun. I previously installed LG pros and those were a breese. The 1 7/8ths ARH need a lot of patience and your car pretty high off the ground if you don't have a lift. The motor mounts have to be loosened (nuts off) and the motor jacked up. They go in from the bottom, once they are close, give them a gentle bang with something soft. Don't set a time or you will only dissapoint yourself.
Old Jul 27, 2007 | 09:18 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the AR's are by far the best system to install, We've done a bunch in the past 2 months at the new shop in FL
the driver's side does install in about 10 seconds, the passenger side takes about 3 minutes
Old Jul 28, 2007 | 10:24 AM
pitboss's Avatar
pitboss
I AGREE i did mine at a buddies shop and found the install very easy and fast. American Racing Headers Vette Doctor series are a nice fit
To ARH Header honest install time
Old Jul 28, 2007 | 11:12 AM
Patches's Avatar
Patches
I recently put a set or 1-3/4" AR headers in from the bottom and both sides went in in just a minute or two each. I removed the alternator and the starter and left the steering shaft and everything else alone. Didn't have to mess with the motor mounts and jack the motor like I did with a set of Kooks. Fit was great.
Old Jul 28, 2007 | 03:47 PM
Showdown's Avatar
Showdown
Nice
Old Jul 28, 2007 | 05:00 PM
Z28TOZO6's Avatar
Z28TOZO6
Thats if he has one of his ace mechanics like doug do it!
