Check Engine Light Power Loss
Old Jul 29, 2007 | 01:02 PM
wildcatgs's Avatar
wildcatgs
Default Check Engine Light Power Loss
stopped at a light everything ok. light turns gree the check engine light comes on and the car has no power limp at 1 mph. dash is flashing reduce engine power. the alternator was in the 12.8 range had the lights on the rear defr,front defr on at the time. waited with the car off for 3 min and restarted. the car has power again but the check engine light is still on any ideas? its a 1997 coupe thanks
Old Jul 29, 2007 | 01:27 PM
ZeeOSix's Avatar
ZeeOSix
Check for trouble codes ... write them down and post them up. This will give you info to pin-point area cause.
Here's a link to help you find the trouble codes.
http://forums.corvetteforum.com/show....php?t=1625418
Old Jul 29, 2007 | 02:35 PM
wildcatgs's Avatar
wildcatgs
THANKS did the codes the first thing that popped up was qc code 424421
then
p1571h
c1278h
u1064h
u1096h
u1255h
it was very foggy this morning i dont know if that was a factor?
any help thanks
Old Jul 29, 2007 | 03:34 PM
Sick Z06's Avatar
Sick Z06
then
p1571h
c1278h
u1064h
u1096h
u1255h
any help thanks
P1571 ASR Desired Torque
C1278 TCS Temporarily Inhibited By PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
U1255 Serial Data Line Malfunction
Sounds to me like you have a ground or battery issue or both. Get a flash light and check around your battery area, and look for ANY signs of a leaking battery and possible PCM corossion issues. If that is ok, check the battery cable connections to the battery (GM has had many issues with the side mount cable connections being poor), if those are ok, it's more then likely the infamous corvette ground gremlin.
Old Jul 29, 2007 | 03:45 PM
wildcatgs's Avatar
wildcatgs
Thanks I Will
Old Jan 8, 2008 | 07:13 PM
varkwso's Avatar
varkwso
What worked?
I have some of the same issues and codes...
To Check Engine Light Power Loss
