no power
Old Jul 30, 2007 | 04:27 PM
Sparky22's Avatar
Sparky22
Default no power
First off I did a search and found no answers. My cigarette lighter on my 02 Z has lost its power. Its the one on the dash. Checked the fuses and all is good. Any suggestions o what could be wrong?
Old Jul 30, 2007 | 05:10 PM
mickey_7106's Avatar
mickey_7106
maybe it unplugged from the back. thats what happened to mine
Old Jul 30, 2007 | 07:33 PM
glkfam's Avatar
glkfam
Default Same trouble at one time
Hi,
Just had the same problem after I worked on the new head unit that was installed. The lighter by the ash tray wasn't working but the one inside the center glove box was. I thought I replaced the clip on plug on the back of the lighter but apparently not good enough. Like Mickey 7106 says that would be my first attack if you checked the fuse and it is good. If not it is time to trace the wire for a lose connection or open, lets hope it is just the connector. It is a pain to take the center console out but when you do it enough it gets to be easier and easier.
Old Jul 30, 2007 | 09:40 PM
mickey_7106
this should help you remove the console http://www.cajundude.com/aluminumbezels.htm
To no power
