Pinging...Yikes
Old Jul 30, 2007 | 05:13 PM
EZEDDIE's Avatar
EZEDDIE
Default Pinging...Yikes
Recently, I developed real bad pinging under heavy acceleration. I surfed the site and was surprised to see how many of you have had pinging problems (some solved and some unsolved). Anyway, I am bringing the vette (01 vert) to CARTEK on 8/7. I know Dave will work his magic. I will let you know the outcome. Maybe it could help some of you. In the meantime, I need to leave my lead-foot at home.
Ed
Old Jul 31, 2007 | 02:48 PM
Julian@Cartek's Avatar
Julian@Cartek
Ed
Looking forward to meeting you…Actually JULIO is our tuner, he will be working his magic on your car.
Old Jul 31, 2007 | 03:23 PM
John G Pircsuk's Avatar
John G Pircsuk
Ed
Your post is probably in the wrong place here...
My Dyno tune at New Era Performance in Rochester, NY took care of the pinging. I was running lean, lean, lean, lena, lean...
Old Jul 31, 2007 | 05:09 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I see you had some issues with your blackwing install. Did your pinging start after that?
If so then you might want to check all your connections to make sure there are no leaks.
Old Jul 31, 2007 | 09:30 PM
zx-12r's Avatar
zx-12r
I have started having the same issue not real bad though. I recently insatlled a vararam.
Roy
Old Aug 1, 2007 | 09:09 AM
EZEDDIE's Avatar
EZEDDIE
Ok..Julio it is! Can't wait to get this resolved!
Old Aug 1, 2007 | 09:14 AM
EZEDDIE's Avatar
EZEDDIE
I had some pinging prior to the blackwing install. Got worse after the install. Actually, once I figured out how to disconnect everything, the install went fine. I checked everything and no obvious leaks. Thanks for the response!
Ed
To Pinging...Yikes
