"Turn Signal Flasher"
Old Nov 2, 2001 | 06:33 PM
wt2ga's Avatar
wt2ga
Default "Turn Signal Flasher"
Where is the "Turn Signal Flasher (Blinker)" located, and how do I change it?
[Modified by wt2ga, 4:56 PM 11/2/2001]
[Modified by wt2ga, 4:59 PM 11/2/2001]
Old Nov 2, 2001 | 06:45 PM
O-Ace's Avatar
O-Ace
Default Re: "Turn Signal Flasher" (wt2ga)
What? :confused:
Old Nov 2, 2001 | 07:42 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Its built in the hazard switch.
Old Nov 2, 2001 | 08:16 PM
LoneStarFRC's Avatar
LoneStarFRC
Gotta remove the upper dash pad to get to it. It's built into the switch assembly and you have to go at it from behind :yesnod:
To "Turn Signal Flasher"
