Problem w/ PIAA 1100X
Old Nov 2, 2001 | 07:10 PM
C5 YA's Avatar
C5 YA
Default Problem w/ PIAA 1100X
I have a problem w/ my PIAA 1100X. My PIAA's stopped working. I checked the fuse in the fuse box. It was OK. So then I got my test light to check and see where I was losing power. I checked the fog lights in the on position and off position. I traced it to the black harness that says PIAA PL5FA. It has 3 pins on one side and 4 pins on the other. The power doesn't go thru, so I unplugged both sides and on one side, there was some green rust. I cleaned both sides w/ alcohol and still nothing. Is this balck piece a relay or a switch? Can you buy it seperate? Anyone have any problems w/ this in the past?
Old Nov 2, 2001 | 08:10 PM
Speeder's Avatar
Speeder
Default Re: Problem w/ PIAA 1100X (C5 YA)
The piece that you are refering to sounds like the relay. Its likely that the contacts inside the relay are corroded as well.
Old Nov 3, 2001 | 12:10 PM
C5 YA's Avatar
C5 YA
Default Re: Problem w/ PIAA 1100X (Speeder)
Doesn't PIAA offer a lifetime guarantee on parts except for bulbs?
Old Nov 3, 2001 | 01:18 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
When my PIAAS were installed we hard wired them in to the existing wiring. Only 3 inches of the PIAA wiring was used without any relays or :bs to go wrong. Maybe you should wire your the same way and eliminate the problem?
vetterdstr
Old Nov 3, 2001 | 02:13 PM
Jim Kramer's Avatar
Jim Kramer
Default Re: Problem w/ PIAA 1100X (vetterdstr)
vetterdstr
DITTO!
To Problem w/ PIAA 1100X
