Cutting out??? MSD wires???
Are the MSD wires new? Have you tested them for resistance? Have you confirmed they are securely snapped onto each coil/spark plug?
Some say that oem GM wires (red or black) are the best to use...
When I first noticed my problem, I was hammering the car on the TRACK
and giving a WRX hell. All of a sudden it seemed as though I hit the rev limiter or ran out of fuel at 6500 rpm.
I instantly let out of it thinking WOW, I just toasted something. First thought was a valve spring. Nope, it still running good when I'm not hard on the throttle. I hammered it again and it starts breaking down, this time at 5000 rpm. Checking gages,, everything is fine. Temp=195, oil pressure 40, Volts 14.1, fuel 1/2 tank. So, I down shifted to third, slowly bring the rpms up to red line and when it started to fall flat on its face at 5500 rpm's the "CHECK ENGINE LIGHT" starts flashing, indicating that I have a cylinder miss. I nursed it to my buddies house 5 miles away and let it cool down and checked each spark plug wire.
Checked 2, 4, 6 & 8. All were on tight and looked good. Checked wires 1,3, and then found plug wire #5 just resting on the plug.
Plug wire 7 was fine also. Reinstalled #5 and went back out WRX hunting!
ONE LOOSE WIRE caused all those issues.Long story short,, LSX engine problems can be difficult to diagnose at first, even for seasoned mechanics. You just need to start with the basics and cover each leg of internal combustion engine operating formula.
Do you have:
- Compression
- Fuel
- Spark
- Correct Timing
As for spark plug wires, they MUST fit tight and read the correct resistance from end to end. For OEM wires, there suppose to read 250-750 ohms. The wires and rubber plug insulators (BOOTS) cant allow any electrical leakage (arcing) and the plug gaps need to be the correct gap and the internal insulator tips cant be soot black!
Do you know how many times that forum members have replaced wires, coils, wiring harnesses etc... only to find out that the spark plug ceramic insulator was cracked???
Don't forget to check that.BC
Checking the wires is very easy just wait until it gets dark outside, raise your hood and start the engine then physically watch both banks while someone else revs the engine, in the dark it's real easy to see bad wires arcing.
)I also went out and bought some basic Champion plugs and try them as well to see if idle cleans up. When I ran a misfire test using EFILive, it seemed like the same cylinders keep showing up.
first .. the boot design makes it difficult to know if the wires are fully seated; poor tacticle feedback when trying to feel the "click of completion"
second, the LS1 set seems to be about 1 inch too short. This puts right angle stress on the boots... making it even more difficult to determine if thet're fully seated or not.
Further complicating the friction needed to keep the coil end from slipping off.
Although I use the provided diaelectric grease on the spark plug end.. I learned to not use it on the coil end... as they were being slowly pulled loose due to vibration and the already mentioned shortness of the wires.
and they work great.
