YOU CAN FIND THEM IN JEG'S OR SUMMIT, I USE THEM ON MY 68 CAMARO DRAG CAR.
All I could find is the dial in numbers. I wanted something larger and in red.
I wonder about stick on shelf vinyl, I could cut out my own numbers with a pattern.
Avery Label Sticker Project Paper 8 1/2 X 11 Stock Number 3383
Use Microsoft Word's Word Art numbers then size it to fit, increase the line thickness, and add a fill color if you like. They go on easy, don't come off at speed, will work in the rain, and come off without any residue or work. I made a whole set to take with me for HPDEs that don't assign numbers before you get there.
[QUOTE=Last C5;1561358386]OK, here is the perfect answer.
I opened MS Word and couldn't find word art, is that on the office disc?
Also, the only contact paper Walmart had, had flowers on it. Hard to find what you need in this part of TN.
