Trans temp?
Old Nov 3, 2001 | 04:00 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Default Trans temp?
What is the average safe temp range for trans fluid? I've noticed mine has been hovreing around 220.
Old Nov 3, 2001 | 05:44 PM
95autoLT1's Avatar
95autoLT1
Default Re: Trans temp? (revo1059)
:cheers: Mine too :cheers:
Old Nov 4, 2001 | 01:49 AM
bparker's Avatar
bparker
I have a B&M tranny cooler - and mine stays about 4 degrees above my coolant temp.. which is between 178-205
BP
Old Nov 4, 2001 | 01:52 AM
ScreaminDemon's Avatar
ScreaminDemon
It's optimal at 178, your hot... :seeya
Old Nov 4, 2001 | 02:36 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Re: Trans temp? (ScreaminDemon)
My transmission temp is about 178 degrees with a Yank 3000 Torque converter and a Hayden transmission oil cooler.
Old Nov 4, 2001 | 04:18 AM
Da Kind's Avatar
Da Kind
Default Re: Trans temp? (Caveboy)
With a tranny cooler, it may drop it down by 20 - 25*.
Old Nov 4, 2001 | 11:06 AM
TLewis4095's Avatar
TLewis4095
Heat is the #1 enemy of an automatic tranny. Mine is rarely over 198 with no cooler, I do have the 172-178 TS & PLII which helps.
To Trans temp?
