Removing the air cleaner assembly
Old Nov 3, 2001 | 05:24 PM
jriordan's Avatar
jriordan
Default Removing the air cleaner assembly
I am trying to remove the air cleaner assembly on my stock Z06. I have taken the
air duct off of the throttle body, released the air duct from the upper support
grommets and the AIR hose is loose, but I cannot figure out how to disconnect the
assembly at the front-bottom. The manual says "Release the air cleaner assembly
with the grommets from the grommet mounting studs". I can't figure out how!?
Any help would be greatly appreciated.
Old Nov 3, 2001 | 05:38 PM
davidfarmer's Avatar
davidfarmer
Default Re: Removing the air cleaner assembly (jriordan)
Just pry it up and off. You will see how to get it back on once you take it off for the first time. It is kinda tight. Don't lose the little rubber grommets.
Dave
Old Nov 3, 2001 | 05:49 PM
99 Corvette's Avatar
99 Corvette
I put a screw driver (between the hood and bumper) right where the air box and the car come together and it poped right off.
Jerry
Old Nov 3, 2001 | 05:52 PM
jriordan's Avatar
jriordan
Default Re: Removing the air cleaner assembly (y2khardtop)
Worked like a charm!! Thanks a lot Dave. Things are a lot easier when you know what you are doing.
To Removing the air cleaner assembly
