Squirrel cage
Old Aug 5, 2007 | 09:10 AM
Keldane's Avatar
Keldane
Default Squirrel cage
I removed my blower motor & inspected it. Looking inside the hole on the side I can see rust all over the insides & in the bottom of outside of motor. Two questions, New blower on order. How do you remove old squirrel cage or should I have replaced that as well? Also, How does water get inside blower motor? Whats going on with water infiltration that obviously ends up resting in the motor. 2000 hardtop Thanks Rich
Old Aug 5, 2007 | 09:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The evaporator inside the air box collects moisture from the air (CONDENSATION) and the COLD air inside the air box gets circulated through the motor via that 1/2" rubber hose If the condensation that collects in the air box cant drain out, it back floods into the motor and will leak inside the car Here is the air box drain:
DRAIN TUBE ON THE FIRE WALL
BC
Old Aug 5, 2007 | 10:38 AM
Keldane's Avatar
Keldane
Bill Thanks again.
I guess I have to remove battery to locate drain hose? Rich
Old Aug 5, 2007 | 10:56 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by Keldane
Bill Thanks again.
The drain outlet is not behind the battery. Is behind the passengers cylinder head. Look where the flash light is highlighting:
If you dont have headers, you can easily access it from under the car. I have reached it from the top but you will come out with wounds!
Old Aug 5, 2007 | 09:03 PM
Keldane's Avatar
Keldane
Default So what about squirrel cage
While replacing blower motor, how do you remove & install used squirrel cage from bad motor to new?
Old Aug 5, 2007 | 09:30 PM
ROJ#79's Avatar
ROJ#79
My new motor came with the cage factory installed
Old Aug 5, 2007 | 10:02 PM
kg54trains's Avatar
kg54trains
I do not know what part was purchased but if its the gm replacement for the blower motor is one piece not two. This is a simple job to complete just getting positioned on the passenger side is the key. Best source for the purchase of the part is GMPartsHouse.com and ask for Gene
To Squirrel cage
