HELP! Both headlights won't go down!
Aug 5, 2007 | 04:07 PM
I had the headlights on earlier, and when I got home and turned them off, neither of the headlights went down to their closed position! I checked the #3 and #4 fuses which should be the hdlight motor fuses, and they are both fine. Is there an additional relay/circuit breaker somewhere that controls both of the headlights?
Please help me!
*edit* I will add that all lights work like they are suppose to (i.e. turns, drls, low beams, hi beams, hazards, etc.) the headlights just simply won't close when you turn them off. No buzzing, clicking, or any other noise like a motor is semi-working. And I just can't imagine BOTH headlight motors to stop working at the exact same time.
Aug 5, 2007 | 04:46 PM
someone has to have some suggestions.
Aug 5, 2007 | 07:10 PM
Start the car and try again....
Mine do this sometimes if I turn the car off before the headlights, why I don't know it just happens.
-KOZ
Aug 5, 2007 | 07:19 PM
Quote:
Originally Posted by
ckoz
-KOZ
tried that, unfortunately that didn't fix the problem.
Aug 5, 2007 | 07:45 PM
Mine are that way all the time.
When you turn them off pull the light stick back as to flash your head lights, That is what does it to mine and they go down.
I also have HID bulbs and something with differnt bulbs causes this minor problem
Aug 5, 2007 | 08:51 PM
AU N EGL
nope, still nothing.
This is really frustrating. Is there a relay somewhere that controls both headlight motors?
Aug 5, 2007 | 11:55 PM
It happened to my car once and also lost all lights on the back and on the dash.... definitively an electrical problem...
Aug 6, 2007 | 12:03 AM
St. Jude Donor '08
yellowcee5
Yes, under the passenger headlight frame.
try turning on your high beams and then turn off your lights.
Aug 6, 2007 | 08:27 PM
still no luck getting them down.
I also noticed this morning that NONE of my interior lights work in the gauge cluster or on the center console!
I think I may cry.
Aug 6, 2007 | 10:34 PM
Then you probably won't have tail light either... A $100 fix or less. I paid $85
Aug 7, 2007 | 08:13 AM
St. Jude Donor '08
frankysuarez
What was wrong ?
Aug 7, 2007 | 09:26 AM
Have you tried to manually close them by using the ****? This would ensure that you don't have a dual gear failure. If both headlight gears failed up, then you will not be able to manually turn them down, in this case you would have to push them while turning.
If you can manually close them, then your gears are okay and the problem is electrical.
Aug 7, 2007 | 10:54 AM
frankysuarez
what was wrong?? Yes, I have no tail lights either.
please tell me what was done to fix your problem. Thank you.
Aug 13, 2007 | 03:25 PM
Sounds like your multi-function switch, its the headlight switch on the column. Some have fixed by spraying electrical cleaner in it.
Aug 13, 2007 | 05:39 PM
Cruise-In VIII Veteran
